Question about HP Photosmart 3210 Printer
Hp 3210 When the machine comes on this message comes on "Ink System Failure" and error number comes on Oxc18a0106. I have check the cartrigdes and even installed new ones. But it still gives the error number. What could be wrong? Orlando Canamar
  • JAMES MASON Nov 06, 2008
    INK FAILURE PROBLEM REGISTERING ON SCREEN
  • 323 Answers
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Apr 19, 2008
Error code OXC4B827F
This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
Jun 24, 2014 | United Stationers HP Photosmart C8180...
Ink system failure error message Oxc18a0106. How do I fix this?
Hello.
Try this
Hewlett Packard Ink System Failure Error Fix (tested C6180) 1- Press and hold the "*" key. 2- Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3- Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M 4. Press and release the right arrow button until the display says "System Configuration Menu". 5. Press and release the "OK" button. 6. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 7. Press and release the "OK" button. 8. Display should say "Hardware failure status: Clear. Press OK to clear". 9. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 10. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 11. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 12. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 13. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
I hope this helps Regards GM
Jul 15, 2011 | HP Photosmart C7280 Printer
It won"t print ,error oxc18a0106
Hope this helps.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
Jan 06, 2011 | HP Photosmart C6100 All-In-One Printer
Cannot print . Ink system has failed. Unable to copy, receive faxes, or print. Error:Oxc18a0106
Try the following steps to remove HP Printer Error Code 0xc18a0001 :
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Jul 22, 2010 | HP Photosmart 3310 Printer
Changed all the ink - all new - still makes a rachet sound and shows Error Oxc18a0106 - will not print - what do we do now to have it print
Issue The product displays an '0x ... ' error message. The exact text of these error message varies by product, but it is usually preceded by the word 'Error .' If your error message includes the words 'ink system failure ,' and you use cartridges 564, 364, 178, 862, or 920, please refer to 'Ink System Failure' Message Displays on the Control Panel Common '0x...' error codes
  • 0xc18a0201
  • 0xc18a0206
  • 0xc18a0306
  • 0xc18a030a
  • 0xd0620130
  • 0x887dd03a
  • 0xd05d010d
  • 0xf0af8004
  • 0xc19ac3ff
  • 0xc18a050a
These error codes indicate that the product has an internal error condition. Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error oxc18a0106 ink system has failed, unable to copy receive faxes or print.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
Says:ink system failed,unable to copy,fax,print error code Oxc18a0106
It means you are out of ink and on newer printers, it can be only one color that will cause ink failure.Check your ink levels and replace the color that is empty.
Oct 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
536 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
