Question about Car Audio & Video
Car remote alarm system
Checkmate model kd-70spc
the remotes are not working even with new batteries. they just flash quickly. The booklet refers to a valet switch to disarm the alarm, but where is it located?
  • Anonymous Mar 17, 2014
    how do I install a new remote to this alarm. I am having problems with the 2 original ones. The company sent me 2 new ones. It says it will only be able to use 2 remotes at one time. I try to install one new one following the directions, but it will not alow me to. I think it is because I need to eliminate the remotes that are already used. I tried to remove the old remote batteries, & disconnect the fuse to the alarm, but none of this helped.
  • 47 Answers
THE VALET SWITCH SOULD BE IN THE DRIVERS KICK PANEL OR AROUND THE LOWER SIDE OF THE STEERING WHEEL
Posted on May 13, 2008
2001 maxima alarm not working but panic works
ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Jan 03, 2018 | 2001 Nissan Maxima
My alarm was working fine then one day i just unlocked the car drove then when i tried locking the car with the remote and it didnt work the light that flashes when alarm is on didnt start flashing it...
Sounds like the unit may have seized (common occurence with this unit). Disconnect the positive battery terminal, wait ten seconds, reconnect. If you have a security radio be sure to have the code handy.
May 22, 2011 | Brand New Prestige Aps787n Remote Startcar...
Replaced truck battery and now remote doesnt work viper ce0890
Hello my name is Israel and I will be able to help you. First I will need for you to look for the alarm unit. The model you are giving me is for the remote not the alarm. Once you have this information, let me know and I will send you the instructions for programing the remote to the unit.
Feb 19, 2011 | Remote Start System
I have a Vermont Casting (Honeywell) remote with 6 buttons. Ireplaced the batteries from the summer and it does not function. the Room Temp shows, the off signal shows and when you press the on button...
It's unlikely that you need a new remote. It simply needs to be reprogrammed with the correct code again. Remotes can "forget" the programmed codes if the batteries run down completely or if the new batteries aren't inserted quickly enough.
Reprogram the codes and it should work.
Please post back if you need further assistance.
Regards,
BElectric
Dec 07, 2010 | Honeywell Televison & Video
Out of range issue on viper 3002
I am having this same exact problem. Have you found a solution to this problem yet?
May 16, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Alarm not working proper
try this. lock car door with key and hold key over for 30 secs then unlock the car with the remote holding button down for 30 secs.assuming the battery in the remote is okay...it should reset the alarm system.
Mar 08, 2010 | 2003 Ford F150 Regular Cab
I have a Mitsubishi FTO with a cobra car alarm model 7777. I have a immobiliser and a key fob but I cannot use the key fob to deactivate the alarm only the immobiliser? Please help
hold down both buttons on the remote till they stop flashing, then press left then press right, this will recode the remote to the alarm. if this dont work try new batteries, if not then find an engineer.
Jan 03, 2010 | Vehicle Parts & Accessories
1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
May 26, 2009 | 4-Button Remote Start/Keyless Entry with...
Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 2007 Mercedes-Benz ML350
Car Audio & Video Logo
498 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
