Question about E-Machines Computers & Internet
I Will like to receive a E-machine manual for model T3626
  • 33 Answers
Go to google and type it in..
Posted on Oct 01, 2009
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Emachine t3626 internet port can it be replaced
Absolutely!
The Ethernet port on your eMachines is part of the motherboard.
It is attached directly to the motherboard.
The eMachines T3626 Desktop PC, is supposed to use an
ECS MCP61-P (AM2) motherboard. (Cannot verify)
(Elitegroup Computer Systems. (AM2) refers to the processor socket )
http://www.ebay.com/itm/MotherBoard-eMachines-T3626-T5062-T5234-W3622-/320528791641
(Also scroll down for a larger photo of the motherboard )
The Ethernet port is in the group signified by the letter A, on the left.
The group signified by the letter A, is in the I/O area.
Input/Output area. This is where Input, and Output devices are attached, TO the motherboard. (Using the motherboard's chipset)
Now look down the motherboard, to the two long white slots.
These are PCI slots. Signified by the letter I ( i )
If one of these slots is not being used, plug in an Ethernet Card, that is PCI.
If both of these PCI slots are being used, use the small white slot above them, signified by the letter H.
This is a PCI-Express x1 slot. If it is available, use it.
Use an Ethernet Card designed to fit, in a PCI-Express x1 slot.
Example;
PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
PCI-Express x1 Ethernet Adapter Card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
[ Note*
The PCI-Express x16 slot that you have, (Orange in color, above the white PCI-Express x1 slot), is for a graphics card.
It is ONLY for a graphics card.
The PCI-Express x1 slot is NOT used for a graphics card ]
For additional questions please post in a Comment.
(If you would like the proper procedure for installing a Ethernet Adapter Card, in your eMachines T3626, also state in a Comment)
Regards,
joecoolvette
Dec 19, 2011 | E-Machines eMachines Desktop PC
My T3626 will only run the fan and the monitor. Thought it was the power supply and purchased a new replacement. Not it! Is this possibly the hard drive? Before I go out and spend what little money I...
try to use only the 24pins or main power connectors and ATX 12volts and without connecting all your hard drives. try to power it. try to use another memory RAM too. second steps try to reset your bios. not successful you have to chage you mother board.
Feb 23, 2011 | E-Machines eMachines Desktop PC
E machine model T3626 Turn on it just whirs--even
this is most likely tye power supply which should be checked -should cure it.
Jun 06, 2010 | E-Machines eMachines Desktop PC
EMachines Power Switch
Rather than hunt for a diagram, take a metal conductor and short out the prongs two at a time until you find the two that turn on your PC. It is 100% safe to do this as you CANNOT damage the motherboard by shorting out the wrong prongs.
Best wishes,
Graemevm
Dec 18, 2009 | E-Machines eMachines Desktop PC
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
EMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
Jul 28, 2009 | E-Machines eMachines Desktop PC
My emachine T3626 will not boot and when it tries it cuts of by itself.
Look for swelled capacitors on the motherboard to the left of the CPU block (should be 6 of them). The motherboard is most likely weak and needs to be replaced if you find swelled capacitors.
Apr 05, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
