Question about HP Photosmart 3210 All-In-One InkJet Printer
HP PHOTOSMART 7180 ALL IN ONE
ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR 0xc0d0281.TURN POWER OFF, THEN ON AGAIN. I ALREADY TURN POWER OFF AND ON AGAIN STILL THE ABOVE ERROR OCCUR. NEED THE SOLUTION URGENTLY. TQ
  • 1 more comment
  • Anonymous May 31, 2008
    ALL PRINT REQUEST RESULT IN ERROR MESSAGE.PRINTER IS ALL IN ONE 7180
  • jbvols50 Oct 24, 2008
    Same problem with the C7280. I have found no solution yet.
  • Anonymous Feb 17, 2009
    same error message i called hp and was told it was a hardware problem that could not be repaired.
How to reduce the baud rate in all in one printer
Posted on May 03, 2008
Hp 7180 foutcode 0xc 18a0201
http://h30434.www3.hp.com/t5/Ink-Toner-Cartridge-Printhead-Issues/Printer-Ink-System-Failure-on-Photosmart-C7180-with-a-MAC/td-p/1220499
Feb 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0306. Ink System Failure?
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0105. Ink System Failure?
May 04, 2011 | HP PhotoSmart 1215 InkJet Printer
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7460 problem
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR...
Ink System Failure is a Hardware Issue, which indicates that the Ink Delivery system failed to initialize.
I suggest you to perform the below the troubleshooting steps, if it doesnt fixes, then the printer need to be serviced or replaced.
1.Turn OFF the printer, unplug the power cable and the USB from the printer.Then Press and Hold the ON/OFF button for 1 minute and then reconnect the cables and try again.If it doesnt fixes, goto next step.
2.Remove the ink cartridges, Turn the printer OFF and Unplug all the cables from the back of the printer.Connect the Printer directly to the wall outlet.Turn it on and wait until u get a prompt to insert the ink cartridges.If it didnt work, go to step 3.
3.Remove the ink cartridges again and close the access door.Disconnect the power cable while the printer is ON.Now Press and Hold the OK and CANCEL button.While Holding the OK and CANCEL button insert the power cable and continue holding the button until u get a message "NVM Reset" or untill the printer goes OFF.Then release the buttons and press ON/OFF button.
4.If you still get the same error, then the printer needs to be serviced.
Thanks
Riz
Apr 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
433 people viewed this question
Seeker5211
Seeker5211
