Question about Brother MFC 210C All-In-One InkJet Printer
How to replace back cover of MFC-210C?
I had a paper jam and had to remove the back cover of the printer in order to remoe the jam. However, I'm unable to replace the back cover. How do I replace back cover of MFC-210C?
  • Helen allen Aug 30, 2008
    had to remove the back cover of the mfc210c and now can't get the cover back on. Help!!
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Posted on Sep 03, 2008
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
My printer jammed. I removed the paper but the screen said to see the trouble shooting guide in the owner's manual. I unplugged it for a while. Now it says "see the routine maintenance guide". I cannot...
Open the top cover and pull the printhead out of the right side to see if a paper scrap was left behind, also on the far left side, the head lies to push scraps into the corners. Pull off the back cover as well to look for scraps, after that the encoder strip could be out of position and you might need a shop repair.
Jan 31, 2010 | Brother MFC 210C All-In-One InkJet Printer
Paper jam problem
Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jam
The issue is with the Paper Feeder roller , either its worn out and needs an replacement.
Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210c
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Jan 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Always paper jam.....
see here: http://www.fixya.com/support/t214938-paper_jam_showing_but_no_paper_in
Oct 08, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
148 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
