Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi Projection TV HD1080
Red/blue/green lines on screen , distorted image, convergence completely off
  • 3 more comments
  • Sicpup34 Jun 01, 2008
    Turned on tv this morning and red and green distortion on left side of picture only. Right side is fine. convergance is way out of whack.... This is a Mitsubishi VS-50800 it wont resolve. Please help!! Thank you
  • dbltrbl73 Dec 25, 2008
    red/green lines on the screen image looks blurred.
  • kosticphx Jan 28, 2009
    I have the same problem with the red, blue and green lines that come up once in a while but it is onda middle of the screen from bottom and the top. The model that i have is Mitsubishi HD1080. What can i do and how much would this cost to be fixed?
    Thanks
  • Anonymous May 16, 2009
    my blue is out of line and i can not get it to move back its a hd1080
  • Anonymous Mar 16, 2014
    i have a hitachi rear projection tv is has red and green lines around the picture
Model NumberWS65909
Posted on Mar 31, 2010
  • Mitsubishi Master
  • 8,617 Answers
You need to replace your convergence ICs. Post your model number of your set, and I will post the correct stk numbers and a link where you can get new ones.
Posted on Apr 16, 2008
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Image distortion
In the customer menu select convergence and then with the Mitsubishi remote select advanced, you should see a grid of lines.
If red or blue or green are out of position you have a problem in the convergence circuit.
If so, I have step by step instructions for this kind of repair and it can be a do it yourself job.
SD TECH
May 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Top of picture has distorted curve
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Toshiba 50H81 projection television
*Screen Looks 3-D
*Colors wont align
Oct 22, 2008 | Toshiba 50H81 50" Rear Projection...
Distorted screen
*Screen Looks 3-D
*Colors wont align
Sep 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Samsung HCN653WX has wavy lines and red and blue ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Samsung HCN653W 65" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
607 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
