Hello there
Please read the entire solution to see which best decribes your problem ok
first.
If neither the oven nor the broiler heats, but the
range burners still work, the clock may be set for a timed or
self-cleaning cycle. Check to be sure the clock buttons and knobs are
set properly. If your clock has a knob that says "push for man(ual),"
push the knob in and try heating the oven and broiler again. If they
still don't work properly, you probably have a defect in the thermostat,
selector switch, or common wiring.
Note… If the oven doesn't have a separate
bake/broil/etc. selector switch, the problem is often with the
thermostat. It's not easy to check the selector switch or thermostat for
proper operation. If you suspect a problem with either of these,
