Question about GE WDSR2080D Top Load Washer
No connection for discharge hose
I just bought a used GE W/D. I can't hook it up because the 'male' piece at the bottom [drain hole] is missing. The hose has nothing to secure to. Does anybody know the part number for SR2080D?
Thank you
  • Hawaii Beth Apr 27, 2008
    That is not the part. That looks like the internal hose and the bottom is the female part I can see at the bottom. I managed [with no help from GE] to find what I need but don't know the part number. It clips into the hose and is screwed onto the two tiny holes beside the opening. It then extends up to the drain with fixed bend to hang.
    I don't know if you can visualize it but I managed to do 3 loads before the on/off knob quit engaging. I'm researching that one now.
    Thank you so much for trying.
    Scholar:
  • 178 Answers
WH41X374 is the part number you will need to purchase. This part is 34.30 from Marcone.com. Check www.partstoday.com for more pricing and availability or ask around a local parts dealer.
Posted on Apr 16, 2008
My ge gts201cncww fridge has ice freeze up in the bottom of the freezer and water drips into the fridge and freezes the fresh food
the drain tube behind the inside rear freezer wall below the drain pan there is plugged,remove rear inner freezer panel you will see the drain tube take a piece of hose and insert it down this drain hole and seal the drain opening as best as possible the blow into the hose to remove blockage,a piece of wire will work too,but the drain is not a straight run and getting a wire down there to remove blockage is difficult,then also put very hot water into the drain hole to help melt ice if this is the blockage problem
Feb 12, 2013 | Refrigerators
How to remove water pump ge front loader washing machine
Pretty simple operation...here's an overview of the component locations:
Remove the 3 screws at the bottom of the front panel. Lift panel out at the bottom and it should fall down. Discharge pump is on the right-hand side. Simply disconnect the hoses from: 1) the tub and from 2) the outbound discharge hose. Then remove all screws holding the pump in place. The electrical is a quick-connect adapter.
Save yourself a mess by draining the assembly first -- just follow the instructions for draining/cleaning the filter in the Use & Care manual
Jul 27, 2011 | General Electric WCVH6800J Front Load...
Unit not discharging through garden hose. Just cleaned unit inside and out. Works great, BUT, only discharges into its container. What am I missing. Cleaned all hoses - no blockages. What should I be...
The blockage is not in the hose, it's inside the hose connection drain tube. To clear this clog, you will need an 18" long plastic Zip Tie, sized to fit into the drain hole. You can use something similar, but NO wire coat hangers. Carefully thread the Zip Tie into the hole and continue to firmly, yet gently work it in, until it reaches a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of Zip Tie. Then slowly pull it back out while rotating it. This will help remove the clog. Once you have pulled it almost all the way out, be prepared for some water to follow.
That should solve the problem for you. Please let me know. Thanks.
May 26, 2011 | Danby DDR586R Dehumidifier
Is it possible to attach a hose to drain the water continuously without my having to empty the bucket every day? If so where and how do I do that? Thank you.
The easiest way is to put a hole in the bucket( by using a a hole saw) and attach a pvc fitting(male adapter with a rubber washer and nut) and hook a hose or pvc pipe that will drain the unit of its water. Good Luck
Jul 25, 2010 | LG LHD45EL Dehumidifier
Water is coming out of air flow gap. I installed a new air-flow gap and all new lines from air flow gap to sink (except the line from dishwasher to air flow gap) and i still have water coming out the air...
The leak in an air gap is usually caused by a clogged sink discharge line. Most of the time this is connected to the garbage disposal and there is food particulate in the drain hole where the dishwasher drain from the air gap to the garbage disposal connects.
Pull the sink connection hose off and clean the hole thoroughly. You can try testing the dishwasher/ air gap by placing the disconnected hose into a bucket during the pump out period. It should not leak. After this test...reconnect the hose to the sink connection.
If it is NOT connected to the garbage disposal then remove the hose and clean out the hole where the connection is made. This is a common problem and easily resolved by the user.
Thanks for using FixYa.
Kelly .
May 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Will not drain.
Elimination Of Problems From Most To Least Likely:
I know you said the drain's not blocked, but i feel obligated to mention it anyways ;)
1. Connection from discharge hose to drain pipe is blocked/corroded.
a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting.
b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver.
c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection.
a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle.
b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c).
c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line.
3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
Sep 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
New hook up for drain on a GE WBB4500GOWW.
On some models, their is a female drain hose that you can purchase from your local appliance parts dealer that should be inserted only. Not your traditional clamp type. Runs about $9 dollars or so and tycally has a triangle collar that is connected along with the drain hose. Does this help?
Jan 26, 2009 | GE Profile WPRE6100G Top Load Washer
GE WDSR2080D Top Load Washer Logo
52 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
