Question about Frigidaire FES367 Electric Kitchen Range
Burners won't stay heated
The two large burners won't stay heated. They will will go on and off on their own to the point where I can't get a pot of water to boil. The two smaller burners seem to work fine. Does something need replaced and if so, what part would it be and how can I find out that's the problem?
  • Magenta88 Apr 16, 2008
    I AM HAVING THE SAME PROBLEM.
    Genius:
  • 1,073 Answers
If you are using the range to do general ever day cooking then if the units are cutting of you could have and infinate control that is bad cutting the element off before the temp heats up the element, you also could have an element sensor that is turning off the element before it gets to the temp that you are wanting.
a volt meter and a wiring diagram is a must to find out what is wrong
Posted on Apr 16, 2008
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
How do you open an alessi pepper mill to refill it?
You will need:- Large cooking pot- Grinder- Tongs- Hot pads or oven mitts (mitts are recommended)- CautionPut the grinder into a large cooking pot. Fill the pot with water until the grinder is completely submerged. Make sure that the plastic parts of the grinder do not touch the bottom or sides of the pot. On the stove-top bring the water in the pot to a boil. Once the water is boiling turn off the heat. The grinder is now very hot and full of hot water so be careful not to burn yourself. Using tongs remove the grinder from the water and hold it upside down to drain most of the trapped water back into the pot. Now turn the grinder upright again to trap any remaining hot water. Using your hot pads or oven mitts grasp the glass part of the grinder in one hand and the plastic part with the other hand and pry them apart. Let both parts of the grinder dry completely then refill it and snap the plastic top back on. These make great grinders for other spices as well such as coriander. Enjoy!
Aug 09, 2011 | Coffee Makers & Espresso Machines
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
The flame are too low, cannot keep a large pot of water rolling boil. was much better when it was new, any adjustment cannot be made ?
check to see if the burners are free of deposits from carbon and grease build up. The tiny holes in the burners get clogged with grease and carbon.
Oct 03, 2009 | Thermador SGS36GS Gas Cooktop
Our Whirlpool speedheat 2600 burners shut down whenever we try to boil water when canning or even making pasta, what do we do?
If the pot is too large or to small for the burner or is concave or convex, the burner will short cycle. Try to match the burner to the pot and be sure the pot is nice and flat on the bottom.
Apr 08, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Frigidaire FES367 Electric Kitchen Range Logo
152 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
