Question about Whirlpool Duet GHW9150P Front Load Washer
F 11 code
Getting an F11 code on my whirlpool frontloading duet. what does it mean??
  • 1,073 Answers
Check the connections between the main control board and the motor control board, make sure that the connections are tight, might bee good to remove the blue and black wired terminals and reseat them if you still have an issue then one of the boards will be bad
Posted on Apr 16, 2008
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ...
    • 6 MIN
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - · PDF file Kenmore Elite He3 F11 Error Code How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Whirlpool Duet F11
    Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
    Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
    An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
    F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
    The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
    The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
    Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
    If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting
    Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F11 code
    Three screws on the bottom front panel. Pull them out and pull down on the panel to remove it. In that panel should be a tech sheet. Look for the f-11 code and follow the directions. I can't remember what that code means, but I think it's long drain or a computer board problem. Sorry I hope this helps.
    Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool Duet front load washer is giving a F 11 error.
    power failure--------unplug the unit for 5 minutes and see if it clears that code
    Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F-11
    F11 Motor control unit internal failure MCU board failure or broken wire.
    Check your wiring harness for a loose connection or a break in the wireaa6d6a5.jpg
    Tech sheets for wfw9200sq
    Jun 27, 2010 | Whirlpool Washing Machines
    F11 and/or dl code on a whirlpool duet front load washer
    F11 is:
    Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Check for:
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Check the above link for a detailed article about the f11 error code.
    Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    The motor does not engage in at all
    The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
    Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Error Code F11
    its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
    Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F-11 code on whirlpool duet GHW9150pw0
    how do I find the answere to the F11 problem posted by jsrock516
    Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    162 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
