Question about Garmin StreetPilot C330 GPS Receiver
Garmin just died.
Just stopped working and is dead. Daughter brought it in house. The cord that goes in the dashboard...is the plug end supposed to be hollow or like a cell phone charger?
  • Anonymous Apr 28, 2008
    WILL NOT TURN ON
It is supposed to be like a cell phone charger. I had this problem - and fixed it by using parts from an old phone charger. I lightly glued around the seal and the problem has not recurred. Hope this helps.
Posted on Apr 17, 2008
Have not used my Garmin since January 2011. Sitting on shelf. Plugged in to my car charger and would not turn on. Would this mean it needs charged?
After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
Apr 18, 2011 | Garmin nuvi 1490T GPS Receiver
How are you doing. i have a house computer and my daughter brought over her laptop and wanted to go online but since her wireless button on her laptop is broke we wanted to just hook her laptop up to my...
if wireless wont work, do wired internet connection. buy a UTP wire with RJ-45 attach to it. plug end of rj-45 to your modem and the other end to the laptop. and setup the internet connection.
Nov 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Garmin 650 won't hold charge in car -- same problem
Check power at the 12volt outlet to insure that you power is on at the connection. Try using a 12 volt convertor in the house to check the cord used in the vehicle.
Jul 23, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin c530 GPS will not turn on
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Jun 21, 2009 | Garmin StreetPilot c340 GPS Receiver
Has been working fine..now will not turn on.
It sounds like a dead battery?
When it is plugged into the car, you should see a charging symbol, or it will say charging if the screen is off.
Are you sure it is getting power from the car? Check the fuse for the lighter socket, also the power cord has a fuse in the end that goes into the cigarette lighter socket, if you twist the end of the adapter it should open and expose a fuse.
Check these fuses to be sure.
Hope this helps.
Apr 17, 2009 | Garmin nuvi 200W GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
to register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Jan 15, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Hand set goes dead
Next time it goes dead, try wiggling the cord where it plugs in the handset and where it plugs into the phone. If the problem goes away, you will need a new cord.
Hope this helps, and if so, please rate my advice.
Feb 05, 2008 | RCA 25202RE3 Corded Phone
Garmin won't stay on
Oh man.. I also bought the c330 on black friday... powers on and wont get past the blue street pilot screen--just shuts off! Will "work" when connected to the PC, but who's going to drive around with a computer?
Is Garmin doing anything about this?
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
