Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50H81 Power but no picture or audio
Scott,
I took the power board loose on my set and looked underneath it and I found a burnt circuit. Next to F852 there is a wire jumper with the number 058 next to it. The circuit is burnt from one side of that jumper to one side of another wire jumper with the number 072 next to it. Any ideas on what could have caused this. Thanks.
John
    Scholar:
  • 170 Answers
Its possible that flood leaked on board from a tube leaking.
clean the area and scrape the burnt area really good so that it won't conduct. then make a jumper from some small wire to the areas you need. check tubes on the bottoms of the metel areas not the crt for something wet... if this fixes your problem then cover your board with a plastic or foam sheet so that it drains forward away from the board. also when you find what tube it is, you may want to ask ways to fix it or how to keep it from leaking.
but if its not a leaky tube then you may have had lightning or power surge. may want to go ahead and check all parts connected to that area for a short. just to make sure there isn't another problem before you start it up.
good luck let me know.
Posted on Apr 16, 2008
When we turn on our Toshiba 50h81, it will work ok for 45-90 minutes, then without warning, the picture and sound will go off and the power light blinks. We have to let it set for awhile (I've never timed...
These Toshiba TVs have a problem on the power board that causes this issue and it is a common one. There are several capacitors on the power board that seem prone to coming loose over time. When they lose connection for a moment the TV's protection system steps in and cuts off power. This causes the 'blinking power light' issue. The last one I repaired was a 43V71 model and I re-soldered one loose capacitor on the power board and it has worked perfectly ever since. Toshiba put out a service bulletin on this problem. It is well known and well worth fixing.
Nov 11, 2009 | Toshiba 50H81 50" Rear Projection...
Burnt smell blush picture
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Dec 22, 2007 | Samsung PCN5425R 54" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
I have no picture and my power red light is
Tell all users of this site that the issue you seem to be facing is common in alot of rear projection tvs. When they shut down and the red light flashes, it may need a component known as a large signal board/deflection board for particular model and brand of tv. Ask a technician for more advice. But i believe this is the issue
Mar 10, 2009 | Toshiba 50H81 50" Rear Projection...
50h81 looks like 3d
It sounds like on of the convergence ICs took the deep six. These are on the Sig/Conv PCB, attached to large heat sinks. P/N STK392-110 (probably) When changing these out, check the power resistors next to the chips... chances are one of the resistors is open.
Jan 05, 2009 | Toshiba 50H81 50" Rear Projection...
Turned on and smoke
Is the burnt circuit on the motherboard or the power switch circuit board that plugs into the motherboard? Big difference, if the burnt circuit is on the motherboard then yes the motherboard is done and will have to be replaced, but if it's just the power switch circuit bard, then this is replaceable.
Aug 28, 2008 | Toshiba Satellite A105-S4334 Notebook
Toshiba 50h81 has power but no picture or audio
is your high voltage still comming up?
ok turning up screen controls with tv on. what do you see?
Apr 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Has Power but No picture or Audio
ok i'm goin to need more info about your problem. you stated fuses and didn't say the location numbers of the fuses. Also, have you rechecked your fuses to see if they are all still good? 3 fuses sounds like more then one problem. once you tell us your loc#'s of your fuses, we can look into your problems.
Apr 07, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba TV model CZ27V51 - Picture+Audo Off, Red light flashing
If you can make the set act up by flexing the board, it certainly sounds like a bad connection. I worked on this specific set before and am well aware of some problems with it. You say you could not find any bad connections.... but do you know HOW to locate them ? Some joints can look perfectly normal to someone who is not experienced but be in fact a bad joint. I don't know how this works...but for a small cash fee arranged through this site, I can give you more specific information on what to look for.
Jan 27, 2008 | Televison & Video
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Toshiba 50H81 50" Rear Projection Television Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
