Kitchen Ranges Logo
Posted on Jun 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upper oven broiler element broken. Need to remove and replace
Upper oven broiler element broken. Need to remove and replace. Model MER6770AAW. Can I do this myself? When this happened we turned to oven off, but it would not turn off. We turned off the circuit and unplugged the stove.
Anonymous
Level 2:
  • Expert 259 Answers
  • Posted on Jun 27, 2010
Anonymous
Expert
Level 2:
Answers
259
Questions
0
Helped
71076
Points
934
Yes you can replace it yourself. Make sure the breaker is off or the oven is un-plugged. When elements fail and burn out they will not stop until they have burned out completely.
The elements in this stove are simply held in place by a couple of quarter in head screws and the wires that connect to them are the push on connector type. There may be a support bar as well that you will need to remove as well to get the element out.
You can do this!
I have a Maytag double oven Model # MER6757BAS. On the upper oven I had to replace the broiler element which was not a problem at all. The lower element works but the upper element does not. Set to broil...
Was the original broil element broken or burnt?
Did you reuse the original spacers to ensure the new element is not touching the oven interior?
1) To determine if the broil element has burned out, use a multimeter to test the element for continuity. If the broil element does not have continuity, replace it. (Perform this test, even on a brand new element).
2) If element tests OK, then reinstall, and test continuity of the element wires themselves.
It really comes down to these two items. Element or wires.
1helpful
Dos wo-227 upper oven relay board
I would look on the internet for places that fix boards they usually charge around 120 dolars there is one in texas just type control board repair. Bye
Feb 27, 2016 • Ovens
Oven element good but does not heat even though broil workes with temp sensor
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
First, your broiler is not connected to your oven thermocouple (Temperature sensor). When you turn on your broiler full load amps go into the broiler element with no adjustment.
There are only three components that control your oven operation:
1.) Heater Element - Inspect your heating element for cracks, sparking or corrosion on the two contacts on the back wall.
2.) Thermocouple - This is a temperature sensor inside your oven. It is about the diameter of a coat hanger wire. Either it comes straight out of the back upper wall or is mounted on the back wall.
It is disconnected and removed from the upper back of the oven.
You should get a meter reading of 1000-1100 Ohms if the component is good.
3.) Oven Control - The control communicates with the thermocouple and increases or decreases the amps to the oven heating element. If the thermocouple is good then the oven control needs to be replaced.
If in unsure, replace them both.
Recently, I replace a digital oven control for a friend. Sears wanted $256.00 for the control. I purchased a remanufactured oven control over the internet for $30.00.
Get the oven model number off your oven. It is on a metal tag on the face of the oven after you open the door.
Go into the following website. Put in your oven model number (on the left). You will get diagrams and parts part numbers. Record these numbers for the above components. Put the part number in your computer search engine and search best price.
CAUTION: If you replace a electrical control board GROUND YOURSELF by touching something that is bare metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Jun 06, 2015 • Ovens
GE True Temp lower element not working after being replaced
sounds like you got a defective element
Feb 08, 2018 • GE Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 • Ovens
Maytag Gemini Electric Range Model MER6770AAW. Upper oven broiler element will not heat up. Took the element to a parts appliance store where they tested it, and the element tested that it was still...
The control to tun the element on must be faulty, you will have to check it with an ohmmeter after youtake the wires off of jt make sure you draw a diagram of where the wires go when you put them back on Make sure to turn the power off before you start Hope this works for you good luck
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
