My Maytag Performa PAV 22300AWW washer works eratically at best. The washer keeps filling completely on any water level selection (mini-med-large-oversize) and now the agitator won't work. I'm thinking it is the sensor. I have located other possible solutions. Should I look at the sensor as the culprit, or may there be another solution. Tks.
    Genius:
  • 1,073 Answers
There is a tube that connects to the water level switch (small med large ) load level, it connects to the outside tub of the washer, inspect it to makes sure that it does not have a hole or crack in it
are you gettting water into the machine woth the power cord unplugged then you have a water valve that is bad , if no water comes into the machine with it unplugged the water valve is ok
if the above two tests are negative then the water pressure switch is bad.
Posted on Apr 16, 2008
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Agitator screw keeps coming out.
New parts !!
Threads are worn and will not lock
Apr 01, 2010 | Maytag Performa PAV2200
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
My maytag performa model number Pav 3200 IS SMOKING
Pump locked up Tip the washer over and take the belt off. try to turn the pump both direction. look for seperation in pump seal. Very easy to replace. Tools needed 3/8th nut driver. water pump pliers. pump is 30 bucks
Dec 17, 2008 | Maytag Performa PAV3200
Maytag washer keeps filling
Bad water valve or syphoning out,to fix this lift up drain hose above water level.it wont b able to syphon
Jun 11, 2008 | Maytag Performa PAV2200
Pav 2300 water over fills even on a mini load past top
check the pressure line from the tub to the water level switch and make sure that it does not have a hole or crack in it if the hose is ok then the water level switch is bad
Apr 19, 2008 | Maytag PAV2300 Top Load Washer
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag performa washer hot water runs continuously
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
