Question about Microsoft Windows XP Home Edition
New screens at Max. size
I used to open new screens and they would already be at Maximum size, why has this suddenly changed and I have to max. each time now?
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
In Windows sometimes it 'forgets' its window placement but luckily we can set it back to maximised windows by default.
To do this please do the following.
* Double-click "My Computer"
* Maximise window by clicking the icon on the top right.
* Left click "Tools" menu.
* Left click "Folder Options"
* Left click "View" tab.
* Left click "Apply to All Folders" in the "folder view" section
* Finally left click "OK"
This will save your window placement to be maximised by default, for any new windows opened.
Hope this helps.
Posted on Apr 16, 2008
How can i install the java game if it says that my *.jar file was over max size?
Sir!
Go to your phone settings and open up the application settings, then there is a option of max file size or something like that then open that option and change it to max size what ever you want. otherwise use the files which are compatible to your phone.
Thank you
Mar 29, 2012 | Samsung M3510 Cell Phone
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    I have just installed the above product. I am running a widescreen external monitor off my lenovo laptop. The issue is that the size of the app is about 1/2 the full screen size....when I max the screen...
    That needs code changes. the program was set to have maximum maximized-window-state size that cant exceed the size you have maximized it to. So, it can't be made more than that unless through the codes by the developer.
    If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
    Thank you and Keep Visiting FixYa!
    Apr 17, 2011 | MyVirtualHome
    Monitor has small message box saying Out of Range when connected to my PC but works fine when connected to laptop lowered to 600 to 800 pixels and notheing changed
    It means that the maximum resolution of your monitor is 600 to 800 only. Anything that's higher than that will not display the screen. Although you can try setting it a bit higher because most of the monitors have a standard screen size of 1024 x 768 but if it's a VGA monitor, chances are the max size is already 600 x 800
    Mar 12, 2011 | Computers & Internet
    P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
    Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
    Jan 14, 2011 | Brother P-Touch 1180 Label Printer
    I want to know maximum card (SD and SDHC) that can be used with Canon Power A550 Camera.
    The maximum size of SD cards you can use is 2GB since SD cards max out there. SDHC cards max out at 32GB. The camera itself does not impose any limits on those two types. In short, you can use any SD/SDHC card.
    Oct 18, 2010 | Cameras
    What is max size HDD for a Dimension 8400
    As far as I know, there is no known maximum size. If you are making it a slave drive, you need to go into your system's BIOS and tell the computer you have a new HDD.
    Restart your PC, and you will either need to hit your F2 key or Delete key repeatedly on boot. Just watch the top right corner of your monitor to know which button to hit.
    Once you're in BIOS, just move to the hardware section or hard drive section and make the necessary changes.
    Reboot and enjoy!
    Feb 23, 2010 | Dell Dimension 8400 PC Desktop
    What is the maximum addressable disk size for a Dell Dimension 2350? I currently have a 120 gb drive partitioned in thirds (40 gb each) that I would like to change to 2 * 60 gb.
    depending on what space you have free is your max, you can use any size you like but again it depends on what is your maximun disk size. hope this helps in some way.. for the size you have now 120 gb, u need at least 10 gigs for windows and programmes to install. so 110 is your max you can play with i think.
    Dec 03, 2009 | Dell Dimension 2350 PC Desktop
    "Jar file is over max size"
    Every phone has a different maximum jar size limit and when you accour this rate you will get this error message. There is no solution to solve this problem. You can't install this jar to your phone.
    Jun 28, 2009 | Samsung J700 Cellular Phone
    Microsoft Windows XP Home Edition Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
