Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Interference with bose sound system
Using Bose LIfestyle 48. Works fine until Pan. Plasma is turned on. Radio tuner will not come in - lots of static. How do I solve? Bose says it's the TV and we have not called Panasonic yet (they are closed right now) but are anticipating they will say it is bose! Any ideas? We have an articulating arm bracket that the plasma is hung on. Could the metal be acting like an antennae? If so, how can we insulate it??
    Brigadier General:
  • 6,966 Answers
Have you tried hooking the Bose LIfestyle 48 to an external antenna? Additionally, you may want to use coaxial cable for the antenna lead in also.
Another area you may want to check is if the Panasonic is using polarized plug with a grounding plug and/or that your house wiring uses a grounding wire other than the live and neutral.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 16, 2008
We have a Panasonic Plasma TV and are experiencing TV signal issues when our Bose sound system is turned on. Is ther anything we can do to improve the signal when the Bose is on (signal fine when we t
Move the insulated cables for the bose away from the cables to the tv. Or go buy monster cables for the TV so there wont be interference. Sounds like power cables are interupting the picture.
Sep 20, 2012 | Panasonic Televison & Video
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Tip
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on May 02, 2010 | Televison & Video
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Tip
I hope that helps.
Can't get sound on tv but dvd and radio work.
Sounds like an install problem. All of your inputs (audio and video) should run through the BOSE and then only the video out needs to run to the TV. In this way the BOSE is the sound source for everything
Aug 30, 2009 | Bose Lifestyle 48 System
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
Jun 24, 2009 | Bose Lifestyle 48 System
BOSE Lifestyle 48 Calibration Issue
try unpluging everything apart from the headset in the aux input (make sure you plug in to the white and red NOT BLACK) Sub woofer and power cord. Also make sure the power is on the the sub woofer. rx7pat
Apr 06, 2008 | Bose Lifestyle 48 System
Remote does not work when plasma tv is on
It is a very strange case that you have.
I think that bose is correct, there is definetly an electromagnetic interference with the system, but the strabge part is that panasonic plasma tvs are not supposed to emit such EMI and they should be shielded.
one advice is that to verify this try putting on the tv, and bring a portable radio close to it and see is there is a change in the sound, if there is one, then definetly your tv is emitting EM fields. this could be due to a factory defect in the tv, have it checked by the retailer where you got your tv.
a second solution is to place the receiver of the bose system further away from the tv and try using both of them.
Dec 07, 2007 | Bose Lifestyle 25 System
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
