Question about Canon PIXMA IP5200 InkJet Photo Printer
Printer displays no paper in tray when it is full
  • 2 more comments
  • Rachielu Apr 28, 2008
    printer says no paper when tray is full!
  • Anonymous May 08, 2008
    prints letters in uneven horizontal levels
  • swissbaer Oct 28, 2008
    The "Out of paper - Printing" message occurs randomly in the property window of that printer (no message on printers display).The paper tray contains enough paper. It seems that the printer driver receives/generates this errenous message and I have to reboot the PC. The printer is connected over USB to a printer server (Zyxel P335 Plus). Direct connection will not produce this message.
  • jemuel osorio
    jemuel osorio May 11, 2010
    what type of printer do you have a laser or deskjet
This is good advise but if you do not know where the papre sensor is then this information is not very usefull.
Posted on Dec 06, 2008
    Scholar:
  • 176 Answers
Try to clean the paper sensor
Posted on Apr 18, 2008
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Paper tray problem - full of paper but can't pull up paper and display says tray empty also loud clicking noise coming from paper tray
hopefully we can stop problem before it gets worse, take paper tray all the way out of machine, look at back of tray where paper stop is, move to LTR make sure arrow is pointing directly to it, not before od after, then lock it in, the pictograhm has a pad lock symbol to show locked and unlocked. if the blue tape is still in paper tray, remove it. hopefully no damage done to pick up assembly, or gears on paper tray
Sep 25, 2010 | Brother MFC-8460N All-In-One Printer
When you try to print from a networked computer the display goes from saying ready to print to load Tray 1 A4. The tray is full of paper
When you loaded the paper in the tray, did you tell it that the paper was A4 - it may be that on the printer or in the queue definition on the computer that the paper size for that tray is set to something else (eg letter) and the print you are sending is A4 so it is looking for paper but only thinks it has other sizes available.
Nov 13, 2009 | Dell 5110cn Laser Printer
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
Oct 19, 2009 | Gestetner 2212 Digital Imaging System...
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
127 people viewed this question
old marine
old marine
