Elgine Battery Wall Clock
I have a huge Elgin Wall clock battery operated. It stopped I put a new battery in it and nothing. Thinking I had a bad battery I bought another..nothing. It does not appear to have a reset button, what else can I try, I love my clock.
  • 1 more comment
  • Anonymous Jun 15, 2008
    The battery (size D) in my Canterbury clock corroded. The battery is inserted vertically and due to the corrosion, the spring is mashed almost flat which results in the battery not making contact at the top. Must I replace the movement or is there a less costly fix?
    Thanks
  • GRANDMAFLCAM Nov 11, 2008
    I HAVE A C BATTERY WALL CLOCK IT WILL NOT WORK I PUT A NEW BATTERY BUT I THINK IT'S THE MECHANIS( THE LITTLE MOTOR) I ALSO WOULD LIKE TO KNOW WHERE I COULD BY ONE THANK YOU
  • Anonymous Mar 22, 2014
    My clock appears to have died. I have checked the batteries they are good. The display is showing straight lines but nothing else. I have tried to reset but nothing happens
    Novelist:
  • 142 Answers
When you removed the battery, were the terminals corroded? If so, clean the terminals on the clock to remove any corrosion.
When you removed the battery , was it difficult to remove? Sometimes during removal of the battery the wires that connect to the termimals will break or come free. If you can see the wires that are supposed to connect to the terminals, make sure they are making good contact and that they too are not corroded.
Good Luck.
Posted on Apr 16, 2008
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
Put new batteries in Howard Miller battery operated wall clock now hands have stopped working. What's my problem?
Batteries were put in the wrong way?
Contacts are not clean?
Batteries were not fresh?
Clock is broken?
Mar 23, 2017 | Home
I have an Elgin anniversary clock that was made by Nisshan Clock Co in Japan. It has no back anymore, it has a red and black button and is powered by one D cell battery. The time is correct but the
Sounds like the element is bad. It is replacable and available online at several places, I have one like yours and that is what I did, its easy to do and will get you ticking in no time
Jan 10, 2015 | Elgin Watches
I have an elgin anniversary clock that I cannot restart after replacing the batery. It has two buttons in the back, one red and one black. How do I restart the clock?
Usually the problem is a bad batch of batteries. Try taking one from something that is working and see if that is the case.
Mar 20, 2011 | Elgin Travel Alarm Clock
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Sep 23, 2009 | Elgin Watches
Repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
Jun 24, 2008 | Kenneth Cole 1213 Wrist Watch
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
928 people viewed this question
 Grubhead
Grubhead
