When I plug the television it makes squeeky sound and it doesn't turn on
  • 40 Answers
Sounds like issue with high voltage circuit, usually not worth getting repaired especially with digital tv conversion happening next year
Posted on Apr 16, 2008
Radio sound low and squeeky, works good in summertime
The volume control on your radio is called a potentiometer, which may be going bad. It works better when its warm because materials expand as they warm up and make tighter contact with each other.
It is also a possible a bad wiring connection exists. Poor contact will cause static, poor audio quality and intermittent output.
Your radio will have plug type connector(s) Your speakers will most likely each have two wires with single female spade connectors of different widths (keeps the polarity correct) the wire with the stripe (of whatever color) will be connected to the negative (-) speaker terminal.
So you need to check all the connections, one is making poor contact.
If both speakers (assuming you have two) sound good or bad... then start with the plug connectors for the radio and any independent black ground wire coming out of the radio.
If one speakers sounds okay check the connections on the other one. You check the connections by carefully pulling the speaker wire off of the speaker and then carefully pushing it back on making sure it feels tight and secure.
PS: If you pull the fuse for the radio, the radio will have no power and will not work. The radio coming on proves the fuse is good.
PSS: Your owners manual should provide lots of information on your sound system components.
Aug 11, 2017 | 2000 Chevrolet Silverado
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Fluttering line across screen after replaceing Lamp
there is no convergence on this set. you have a problem on the FMT and the DM pcb's.the chassis needs to be rebuilt. email me or go to
May 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Disney tv has a picture but no sound
Common issue with some of the TV sets. If your headphone socket is squeeky clean it is more than likely a manufacturers fault. Please seek a re-fund or contact the manufacturer
Oct 12, 2008 | Disney 13" TV
NO PICTURE/wega kv-32hs500 32"
squeeky wheel sound and turns off. as there is no light also. please check components in horizontal section. it is a simple problem can fixed at your at home easily Do I need a new T.V.? NO now choice is yours good luck
Sep 25, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
