VCR player won't play - Televison & Video
  • 2 more comments
  • wordking Apr 16, 2008
    2006 Model NV-VP33, DVD / CD Player, Video Cassette Recorder / Player.
    After inserting a cassette in the VCR, it plays for a second or two then stops.
    Everything worked perfectly till a few weeks ago.
    Useless advice - any tape that is placed in the VCR begins to play and then stops. Why?
    That's better!! Looks like I'll have to take in to a service centre, not a good advert for a player less than two years old. Thanks
    2006 Model Panasonic NV[vp33 DVD / CD Player, Vdeo Cassette Recorder Player. Tape runs for a second or two then stops. The tape's content shows briefly on the monitor. There is no spin or whirr. Just the click of the tape stopping.
    Brigadier General:
  • 6,966 Answers
Assuming that the VCR powers up and the display shows the usually indications indicating no electronic problem, then it is possible that the reason the VCR won't play is because of a mechanical defect.
If the tape will load (slide in even if only partially) but won't play (and auto shuts off), the most likely problem is the belt in the loading motor. it could either be slipping or cut.
If the tape will not even load, then it is the frontend of the loading mechanism.
If on the other hand the problem is electronic, then you would need a service manual or at least a schematic diagram to diagnose. This of course would also require that you be familiar with electronic components and circuitry, the use of a DVM and a soldering iron and safe working practices involved in working with electrically powered devices.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 16, 2008
  • 3,037 Answers
Can you please be a little more specific on this problem please.
First, brand and model of the vcr.
Next, what exactly is happening? (example: can you load a tape and press play and have it try to run or won't the reels spin, etc.)
We need you to help us so that we can help you. This is like asking someone to buy something at a store that they need without telling them what. Thank you for using fixya, will be waiting for your reply.
  • Benjamin Patri
    Benjamin Patri Apr 16, 2008
    thanks
  • Benjamin Patri
    If both reels are moving, and the tape isn't being eaten, then I put
    money on a very common thing on those; Reel sensors! It's a bit tricky
    to replace them, but I bet that's it. They're phototransistors located
    on the bottom transport PC board, and they pick up mirror squares on
    the bottom of each reel. As the reels turn, the mirrors pass the
    phototransistor and tell the VCR that the tape is moving.
    Please let me know if you need any additional help
  • 74 Answers
Make sure it is pluged in to the wall
Make sure their is a tape in it
make sure you hit the power button on the VCR itself, not the remote
make sure you hit play on the VCR it self, not on the remote
  • 758 Answers
You might want to buy a tape cleaner...what exactly happen when you tried to play the tape?
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
Will philips dvd 3345 player play avi files
I find the reason and solution for avi won't play in a DVD player from this article https://www.idealshare.net/video-converter/avi-dvd-player-solution.html DVD Player Won Play AVI Solution Convert AVI to DVD Player Format
Nov 07, 2012 | Philips DVP3345V/17 DVD Player/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Why Philips dvd player won't play all dvd movies?
This is not a fault. Some movie burned formats might not support the player.
May 23, 2012 | Insignia IS-DVD1001 DVD Recorder/VCR
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
I received a freebie DVD player but it won't play DVD it keeps saying no disc
The problem is in the laser pickup assembly, buy a DVD cleaning kit and follow instructions, it may help buy more time if not! replace the player not cost effective to repair.
Mar 24, 2012 | GoVideo DVD-VCR Combo
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
How do I turn off the Progressive Scan on the DVW-7200 DVD/VCR. when it's on, the thing won't play any type of media
ok alot of people wrote a review to other questions similar to this one.. and they forget one key instruction. it has to be the play button on the dvd side of the combo player physically not the remote you press and hold the actual play button on the device for 5 or more seconds and the light will turn off. Then it we play and there will be a picture on the screen.. i hope this helped because that is how i fixed mine.
Jun 21, 2011 | Sanyo DVW-7200 DVD/VCR
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
We have a GO DVD+VCR model No. DV2140. We cannot
If you are trying to play blue ray on this unit you are out of luck no amount of firmware will make it play something it is not capable of doing.
Aug 14, 2009 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
