Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother mfc MFC-5440CN magenta issues
I have a brother mfc 5440cn printer. I am un able to use the magenta color ink cartridge. I have cleaned the printer heads 5-6 times, and I have also update the firmware on the printer still no magenta printing. Please can some one help.
  • 3 more comments
  • Genma Apr 16, 2008
    Thank you , I am going to try that will tell if it works. Where could I purchase the printer head to replace it with, or do you have be a repair shop to get hold of that part?
  • Jokester832 Apr 30, 2008
    Interesting enough I also lost the magenta color on my same Model MFC-5440CN. I wonder if there's a systemic problem with this printer as to why the same color goes on these assuming others are having the same issue. I can't believe they don't sell a cleaner cartridge for these machines ?
  • Anonymous Jun 25, 2008
    My 5440cn says NO CARTRIDGE. Its the magenta. I see others have same issue but I dont see a resolution. Any ideas?
    ps. cereal in my bowl in the morning last longer than these POS cartridges.
  • Anonymous Jun 26, 2008
    I have the same problem, after cleaning , nearly 10 times still magenta would not print, when i try to test print the page other three > black, cyan,yellow are printing but block of magenta lines is missing. does any one know how to clean the clogged head ? or any other solution to this problem.Thanks in advance.
  • Akash01 Jun 26, 2008
    After cleaning nearly 10 times , magenta color lines on the test would not print , only black , cyan and yellow are printing but no magenta lines are on the test page.
    Does any know how to clean the head or any other solution as this printer is out of warranty period now.
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
  • 832 Answers
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Posted on Apr 16, 2008
  • Mix-it-up
    Mix-it-up Apr 16, 2008
    YOu can buy it from a service dealer (quite expensive!).
    Another way is to buy a defective dcp 115c or 110c with a broken scanner and use this ph as a spare part.
Brother Mfc-5440CN Yellow and Magenta will not print. Opened holes on top of cartridges and still will not print. Can you help me?
Have you executed a forced head cleaning?
Are you sure that the cartridges are correctly placed and the output punched ?
Oct 28, 2011 | Brother MultiFunction Center MFC-440CN...
Brother MFC-5440CN wont feed 2 colors of ink, Yellow and Magenta and also says
This may be due to the fact that you have not removed correctly the small label that seals the air input to the cartridge. Normally on brother cartridges it's on the back or on the top of the colored label. Please check that. If no air is allowed in then your ink will not be provided thus generating your problem.
Oct 27, 2011 | Brother MultiFunction Center MFC-440CN...
Just refilled the Cyan and Magenta cartridges and it's still saying that they're low. Help?
The color printer might not print in color due to dirt and other unwanted particles present in the printer. Due to this unwanted particles, the ink used for printing and other materials might become blocked inside the printer device and this might lead to some printing issues. In order to resolve this issue, regular cleaning of the printer is necessary.
Dec 29, 2010 | Brother MFC-5440CN All-In-One InkJet...
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5440CN The black line of the ink is "clogged"
Hello sir; If you use auto feeder and print out with black line then you have go to clean the glass (small portion one ), if you make copy with black line then you have go to clean up print head( if your machine is inkjet) or you have to replace toner cartridge ) if your machine is laser jet).
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
My printer not working
it sounds like a manufactuer defect
May 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Oct 24, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
638 people viewed this question
James Cagle
James Cagle
Jim Keysor
