Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Beeping sound coming from fan
My hood fan is beeping like a siren when its not on what does this mean?
I just installled this weekend
  • 40 Answers
Open wiring area up and find where noise is coming from. There is a electronics board in some fans that might have a warning buzzer of some kind.
Posted on Apr 16, 2008
My alarm system siren is not working how can I fix this
Without knowing the make or model of the siren - and without knowing if it as in "all in one" unit with the siren, controller all in one - it is difficult to offer much help.
If the siren is a separate item, connected by a wire, then if it is 12v, you could try disconnecting it from the alarm controller and see if it works - then you would know if the siren is damaged or if it is the controller that drives it.
SOME sirens will be rotating fan, others will be 12v operated and some will actually be little more than a horn speaker - driven from an amplifier inside the control module.
Can you give us some more info please - make, model, what you have tried, does ANYTHING on it work (lights, beeps, flashes the indicators etc)?
Oct 12, 2017 | Vehicle Parts & Accessories
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
I have encountered a high and low beep from my mother board, what would be the problem of my board and solution of this problem? but before i have first encountered a constant reboot of my computer it just...
Remove your processor cooling fan from the processor, then clean the fan with high pressure air blow and clean the top side of ur processor, and get a good heat sink solvent {not the white one}
it will come in grey color 10ml package i think, and apply half of that and fix... Actuall mean for the siren is system halted with thermal shutdown...
Sep 17, 2010 | ASUS Computers & Internet
It makes few siren sounds, and then display "boot system failure"
Never heard of a HDD making siren sounds but if you mean a series of beeps from your PC then they are codes which indicate the problem.
See here for how to interpret them.
Sep 02, 2010 | Western Digital Caviar WD450AA 45 GB...
Microstar ms-6390 will not boot. The fan starts then stops as it begins to beep. The beep sounds like a siren or something high tone low tone over and over. It only stops when power is disconnected or...
The problem is-- your motherboard is not able to detect the system RAM.It's the sound you hear as siren.Open the PC and slowly remove the RAM from motherboard and clean the slot and the RAM legs with a clean white paper and place it again.It will solve your problem instantly if the RAM is not burn out.check the other RAM slot by placing the RAM again if the above procedure does not work.
If the problem still persists,replace the RAM.
Dec 14, 2009 | Compaq Presario 5000 PC Desktop
Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
Jul 30, 2009 | Computers & Internet
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Apr 18, 2009 | Abit KN9 Motherboard
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
574 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
