Question about Canon BubbleJet i560 InkJet Printer
Canon i560 won't print black text anymore
Canon i560 just stopped printing black text, all in tanks are full, when i do nozzle check and test page the black works, but when i try to print out a plain black text page it wont print but coloured graphics print out ok
  • 8 more comments
  • Anonymous Apr 26, 2008
    MHL reports: I have the identical problem: all tanks are full, the
    testprint produces black text output, but printing black text from for
    instance MS-WORD produces a coloured result.
    The answer from jeffdynamics I'm afraid just begs the question, i.e. was little help, because it didn't address the problem described. Has anybody else got any ideas?
  • JTruant Apr 26, 2008
    The
  • Anonymous May 09, 2008
    black ink does not appear on the nozzle check and printer does not print in black anymore either only grey and colour
  • Bobuszka Dec 10, 2008
    Specifying "Transparency" worked for me in producing text but very, very slow. Wouldn't like to rely on this workaround for too long. Anyone got THE solution?
  • Anonymous Dec 25, 2008
    My printer won't dispense ink in any mode (test page, normal mode). However I only have a black ink cartridge. It was working fine for two years without color cartridges. I have tried all the types of cleaning methods suggested by canon.
  • Anonymous Dec 31, 2008
    Bobuszka, you are a genius!!
    I had the same problem. Repeated cleaning cycles had no effect. Okay on color, terrible on black. Took the cartridges out, removed the print head and found the underside had accumulated some gunk. Since I had nothing to lose, I followed your suggestion and washed it with hot water and some q-tips. Now it prints perfectly!! Thanks so much!!
    Clearly I would vote for your answer, but I'm too lazy to register.
  • Anonymous Mar 23, 2014
    how to print test page
    printing test page
  • Anonymous Mar 25, 2014
    prints a test strip in all colors but not the documents I need from the computer
  • Anonymous Mar 27, 2014
    page prints fine, but prints a lighter shadow of text on the page
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Posted on Apr 26, 2008
I had the same problem, even when I only selected grayscale printing, my printer would use all 3 colors to make black, and my black cartridge would never get used. Try this:
On printing preferences change your Media Type to Transparency.
This should solve the problem and stop robbing your color tanks when you just want black
Posted on Oct 16, 2008
Re again jimmyphor's suggestion that specifying Media Type as Transparency will save on colour inks when all that's wanted is black. I suspect that the "black" produced by this method is from a combination of the other colours and therefore will not save on these inks. However it does prove that the print-head is OK.
I solved my similar problem (suspect may have been caused by one refill too many), by removing the print-head and cleaning it in hot water (I'm advised cartridge fluid will also do the job), gently shaking it, dab around with cotton bud and giving it a ********. I then installed a nice new expensive official Canon cartridge. Ran the print-head alignment and nozzle checks and it's now as good as new.
Posted on Dec 12, 2008
    Problem Solver:
  • 18 Answers
I have 3 option with your problem first is to replaced inktank cartridge second one is check and replaced printer head lsat is check and replaced purge unit...tnx and good day
Posted on Apr 16, 2008
SOURCE:
My Canon MP560 won't print black
I have problem with my canon IR 2420 DISPLAYING E000007-0000
WHAT CAN BE APROBLEM
Nov 17, 2013 | Canon MP560 All-In-One InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Prints black on test page, but not when a job is sent to the printer
make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Oct 18, 2007 | Canon BubbleJet i560 InkJet Printer
Won't print text or test page
try with diffrent printer driver and see. bye
Sep 22, 2007 | Canon BubbleJet i560 InkJet Printer
Lost B&W printing
Hi marc, it sounds like the normal clean has not eliminated the clog you may have in back printhead. I need to know if you refil your own cartridges or not to be specific, but basically you need to remove the black ink cartridge, and clean the printers heads yourself, and right down where cartridge sits wth cotton buds and proper cleaning solution. Wipe the surface of cartridge if it has the printhead attatched (some printers have the printhead on them, some have it on the cartridge. Replace ink, reset black ink level, cancel the alignment for now, go straight to printing. Print a test page and see how it goes.
Jan 26, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
3,251 people viewed this question
Clive
Clive
old marine
old marine
