I have had a Hitachi CM721F monitor for about 3 years now, and the focus is getting fuzzy. Is there any way to adjust the focus?? The brightness is fine. Thanks!! Dave Barnes, davidb1569@aol.com
    Scholar:
  • 176 Answers
If you can open your monitor you can adjust the focus in the back of the plyback of your monitor. But be careful to touch other parts of the monitor to avoid damage to the monitor in to your self. Use sharp thing or plastic to adjust the focus in the plyback. When you open the monitor cover you can find the plyback in the back end of the board of monitor usually color black and there are four wire connected to the board in the monitor yoke. Look for the two holes adjustment the upper one is for the bright and the lower one is for the focus. open the monitor and adjust the focus slowly again avoid to touch the other parts of the monitor. goodluck
Posted on Apr 16, 2008
Image not focused
Possible worn out tube. The focus adjustment is on the flyback transformer and has to have the back cover removed to access it. The flyback will be a black and have a red wire connecting to the crt tube. This is very high voltage and can be dangerous. With a plastic screwdriver you can turn the focus adjustment knob on the transformer. Do not adjust the screen control knob. If the focus does not clean up, then the tube is probably worn or the flyback is bad.
Nov 27, 2013 | Samsung SyncMaster 1100MB 21" CRT Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Photos out of focus
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD1000 Digital Camera
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Fuzzy Rear Screen Projection TV
Probably the EHT unit is failing or the Focus Control is out of adjustment or if it gets worse as the brightness increases, may need a new TV.
Apr 02, 2017 | Televison & Video
Convergence problem
This is a common television flyback transformer , it has two potentiometers ( POTS ) variable resistors , how ever you wanna say it , the one above has 3 , one of them is the focus
you can use a plastic screwdriver or plastic wand , or small metal screw driver if nothing else
Here's a closeup of one that has only two potentiometers
One of them is the focus adjustment
to adjust the focus/sharpness of the image you see on the screen
1. find which one is the focus , you will know because adjusting it out of calibration will cause
the screen to go out of focus untill you adjust it correctly.
to adjust it correctly , rock it back and forth untill you see the sharpest image , then your done.
if you accidently get the wrong one by mistake your screen will increase in brightness
set the brightness lower rather than higher , because you don't want it to be over saturated.
Az.
Sep 16, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Display problem
A fuzzy display is not likely to by caused by programs on your computer. Is this an LCD flat panel monitor or a regular CRT monitor?? If it's a CRT, the problem could be with the high-voltage power supply, which would need to be diagnosed by an experienced computer1.gif or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 18, 2008 | Gateway FPD2275W LCD Monitor
Fuzzy, unstable display
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Jan 15, 2008 | Sony GDM-C520K (Dark Gray, Gray) 21" CRT...
Unclear images
Remove the rear cover and adjust the focus control on the flyback. Use a non-conductive probe, available as adjustment tools from any radio shack. On the FBT (Flyback Transformer) you have two protruding adjustments - one marked screen, the other focus. The screen adjustment increases the G2 voltage to the crt and brightens the picture by increasing the voltage exponentially. You don't want to adjust the screen voltage. The other is the focus, you can easily turn that clockwise or counter clockwise and watch the screen to set it at your preference.
Hope this helps.
Bill
Nov 11, 2007 | E-Machines 17F2 17" CRT Monitor
HP-71 D8901a with fuzzy video.
a weak or defective Picture tube can also cause a crt to get fuzzy or out of focus.
May 19, 2006 | HP 71 17 in.CRT Conventional Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
