Question about Epson Stylus C88 InkJet Photo Printer
Changed cartidges & now black and blue don't print on C88+
This is the 2nd or 3rd time this has happened and I don't remember what we did to fix the problem.
Ink was low and it seems like it always happens when I change the blue cartridge.  I changed black and it was fine but then immediately the blue also needed changing (it was out too) and when I changed the blue, that's when both blue and black stopped working.
I cleaned print heads using the correct utility and still nothing - only red and yellow print.
I think I changed the ink cartridge and that solved the problem last time - bad cartridges?  But they are new and genuine Epson, bought at Office Depot, not expired, etc.
Any help is appreciated....
Thanks,
Chris Jacobson (714) 505-0605 x102 chrisj@calevents.com
    Genius:
  • 1,447 Answers
Try to remove and reinstall the blue and black cartridge and check if you punctured the plastic cap underneath the cartridge itself. then reinstall it and make sure you hear a click or it snaps in. try head cleaning cycle from the utility and print a nozzle check pattern. If same output maybe carts are bad. If that is a genuine epson ink cartridge, call epson and have the ink cartridges replace since they are new ones and for sure epson will send inks since you just bought it. make sure you have date of purchase handy.
pls dont 4get to rate solution if it helps... thanks!!
Posted on Apr 16, 2008
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Irplaced othe the black and color cartidge on printer, when i go to print it gives me ink cartidge is missing. how can i fix it?
did you remove the tape from underneath the ink cartridge ? did you also bring the blue levers down to lock the cartridge in place ? try removing and putting the cartridges back in the printer. they should go in easily. Good luck
Jan 11, 2011 | Dell A940 All-In-One InkJet Printer
I just fix in new black and coloured cartridges and only black and red colours appear on my prints. the replaced coloured cartridge was giving similar print problems.
hi im josh in cebu phils. friend may i help you? it happen try to shake the cartridge that doesn't print.and install it again and just remember this: Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. so thats all good luck
Mar 06, 2009 | HP DeskJet 1280 InkJet Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
HP Color LaserJet 2600n
you probably needt o change the transfer belt which is the "black roller film". you can try wipping it off with a dry lint free cloth.
May 16, 2008 | HP Color LaserJet 2600n Printer
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com for further assistance, I'll be glad to help you.
Bye
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
Epson Stylus C88 InkJet Photo Printer Logo
203 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
