Question about Indesit W 123 Front Load Washer
Wire has come out of the rubber part of the machine
The rubber part round the door a round piece of wire has come away so machine leaks
  • Anonymous Mar 14, 2014
    wire round door rubber has come off
  • 975 Answers
IF THIS TYPE OF WIRE like a spring WIRE?? ELASTIC? if it so , need to replace for a new one , with time these wires looses strength , go to any appliances parts store with make and model and take with you the wire. hope it helps.
Posted on Apr 16, 2008
Model #FFLE2022MW0 Frigidaire washer leaking water at bottom
pump housing cracked by coins or wires leaking
or rubber somewhere
if you isolate the water and waste and mains
the lay it over on the side away from the soap drawer
it wont leak
and you can access under it
and investigate where the water is coming from
bet you its the pump plastics cracked ,..
i would do this now dont use it for now
and fix it
this type of error can cost you a controller board ...
you can save lots of time by checking round the door seal of rubber issues inside its folds etc
but i still think its the pump or some rubber hoze loose
see in being one of the intakes or perhaps the drum from drawer rubber ... so
lay it over and check
no chance of fload if you lay it over on the side away from the drawer with the door closed
Apr 28, 2015 | Frigidaire Washing Machines
Wire came out of front plastic gray circular piece and washer leaked water everywhere
Sounds like some article of clothing got between the door glass and door boot and pulled the rubber door boot away from the front of the washer. Check and make sure the rubber boot is not torn. If it is ok you should be able to slip the lip of the door boot back onto the front of the washer, make sure you get it in the grove. Then put the wire retainer back around the boot, you may need an extra hand or two to hold it and stretch the spring back on. Hope this helps
Sep 02, 2011 | Kenmore HE2 Plus Front Load Washer
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
The rubber has come of the washingmachine door and their is a round wire with spring attached and i am not sure where this goes i know it holds rubber onto door but not sure how.
toput it back on you thred it round the door and you put the wire with a spring insine the rubber there should be a notch all the way round you thred it round the door to hold it so it dosent come off the wire is a restaining clip to hold it on when you done this make sure the rubber dosent move hope this helped
Aug 31, 2009 | Indesit W 123 Front Load Washer
A piece of fabric got caught in the seal and it it slightly torn and the seal is warped. A round wire with a spring fell out and the door will not close.
you will have to replace the boot glove as this is what i think you mean,the part were the door fits into,if there is a rip in this rubber boot then water will leak through teribly,the round wire you refer to is the wire that goes around the boot to hold this securely to the washer preventing it from leaking,hope this helps,rgrds,paul
Jul 07, 2009 | Kenmore HE2 Plus Front Load Washer
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
W620 Drain Hose Goes Where??
The little black hose in the pin trap compartment gets hooked onto the round pin on the door of the pin trap access, that little hose is a bypass hose from the pump inlet
hope this helped
Apr 18, 2008 | Asko W620
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Indesit W 123 Front Load Washer Logo
83 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
