Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Error code E 4 54040990
I am having trouble (that is an understatement) dubbing from VHS to DVD on my unit. I have successfully recorded from the tv onto DVDs, however when attempting to dub using the same discs, I get the error message: Recording Error, Can not record on this disc, E 4 54040990. The VHS record tab is intact, the DVD+R is long enough to hold the movie, and the record mode is set at 2hr (the length of the DVD+R). Any suggestions.
  • 1 more comment
  • cadcat Apr 17, 2008
    YEP! Same exact problem and the frustrating part is that it use to work fine when dubbing my home movies. For some reason it would only record on DVD-R and not the DVD+R - now it won't do either.
  • Martina_C Apr 23, 2008
    I have the same problem with new discs, after several attempts I was able to record on a disc I had started but not finalized but first I needed to turn off the disc protect, sadly I can not get into Disc edit on a new disk.
    a solution would sure be nice.
    Martina
  • Anonymous Jul 14, 2008
    MY RECORDER WILL NO LONGER RECORD ON ANY DISC. I'VE TRIED ALL TYPES OF DISC (+R / +RW / -R / -RW), AND ALL BRANDS.IT WILL NOT DUB TO DVD OR RECORD FROM LINE IN. WHEN I FIRST GOT IT I COULD RECORD ON ANY DISC. I DUBBED MY OLD VCR TAPES, AS WELL RECORD NASCAR EVERY SUNDAY. THEN IT JUST QUIT. IF ANYONE KNOWS HOW TO FIX, IT WOULD BE GREATLY APPRECIATED. THANKS.
  • 4 Answers
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
I have the same problem . sometimes recording on a new memorex disk i record for 4 or 5 seconds and hit stop it writes it to disk and then i have less problems with recording it but sometimes still messes up i bought a 50 pack and about half are worthless im not buying the disks again to much headache ill go with another brand that works for my dvd burner. also play back seems to pause at times. its been driving me up the wall. if anyone has a beter idea id love to hear it
Posted on Jul 12, 2008
SOURCE:
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Dubbing vhs to dvd disc
I don't think it's the TV...IF you are recording from cable, some cable companies put out a anti-copy, or one copy only signal on some programs. It will interfer with your home usage. happened to me. I DVD'd '24' last year, and when a friend wanted to see an episode he missed-I popped my DVD in the computer, and the computer refused to burn the disk- The actual title on the disk(that I did not put there) was"COMCAST".
Jun 23, 2008 | Televison & Video
Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Apr 20, 2008 | Philips Magnavox DVD/VCR Dual Player
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
1,926 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
