Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Cannot record on +DL - Dual Layer Discs. Maybe it is the brand?
I bought a 5 pack of Memorex DVD+R DL discs. I tried all 5 of them and none of them work in my Panasonic DMR-EZ475VK. I called Panasonic and they said they think it is a problem with the discs and not my unit. Naturally we went through the process and I told him what the screen and display said regarding errors.
Has anyone else had any problems recording DL discs? I was thinking of buying Sony DL dics instead but thought I would check out this forum first. Thanks!
  • ChicagoPunky
    ChicagoPunky Apr 17, 2008
    Thanks so much, Mark! I thought I would try Sony since I have never had a problem (knock on wood) with them before. I bought a 10 pack - least amount I could find.
    I put the first one in and it worked perfectly! Right away, too. So you were right on with what you wrote about the discs. Thanks again!!
  • 472 Answers
The discs could be the problem. Even in the same model you will find some that reject a certain type of disc, and yet the one made directly after it on the production line will be fine. The same applies to PC burners.
Other times those same discs will be rejected or accepted. It's all about the fine lines in production. A minor difference to things like the laser when it was assembled, or the dye used in the discs is all it takes.
This is why most companies will have a reccomended set of discs that are known to work due to them being manufactured to a higher standard. Between the higher and lower is not alot, but enough to cause problems.
Look for a place that sells discs as singles, then get one and try it out. The other thing to keep in mind is the more expensive discs will hold the data better, longer and with less errors.
Posted on Apr 16, 2008
  • Peter Thompson
    Peter Thompson Apr 17, 2008
    All good glad you have it sorted.
    Since the Sony discs work, also try Verbatim etc.
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
What kind of blank DVDs do I use to copy an old VHS video tape to the DVD? I have the Sony RDR-VX530. When I put a DVD in, I get an Error message saying that I have the wrong DVD.
According to page 30 of the operation manual, the following information may help;
DISCS THAT CAN BE USED IN THIS RECORDER:
4x-speed or slower DVD+RWs
2x-speed or slower DVD-RWs (version 1.1, 1.1 with CPRM) (Content Protection for Recordable Media)
4x-speed or slower DVD-RWs (version 1.2, 1.2 with CPRM)
16x-speed or slower DVD+Rs
16x-speed or slower DVD-Rs (version 2.0, 2.0 with CPRM, version 2.1, 2.1 with CPRM)
2.4x-speed DVD+R DL (dual layer) discs
(when using DVD+R DL discs, see the instructions supplied with them prior to use)
4x-speed or slower DVD-R DL (dual layer) discs
DISCS THAT CANNOT BE RECORDED ON:
DVD-RWs (version 1.0)
DVD+RWs that are not 2.4x-speed compatible
8 cm discs (mini-DVDs)
DVD-RAM (any speed/any version)
DVD-R DL (dual layer) discs in VR mode
A free pdf copy of the manual for this model can be downloaded online.
Hopefully that provides some insight to your question.
May 25, 2011 | Televison & Video
What does memorex dual layer dvd+r mean? How do you record a movie that is over 130 min. We purchased 240 min just for this reason and we can not get it to record over 120. How do you finish recording the...
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
May 12, 2011 | Memorex Products - Memorex - Dual-Layer...
I recently purchased a pack of staples brand DVD RW's instead of the name brand ones I usually use. When I insert them into the player I get an error message stating that it cannot record on this disc ( E...
Please check if your blank DVD's are dual layer ( DL ) 8.5 GB disc. If so your player does not support dual layer writing. It will record only on 4.7GB single layer blank discs.
Apr 22, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The DVD Burner will not burn a Memorex DVD - R . Should I purchase Verbatum or Memorex for an older model MSI DVD Burner? Or, Should I purchase Verbatum or Memorex for an older model Samsung TS H652...
You are on the right track. Every "multi-format" DVD recorder, DVD burner and DVD-RW drive I have ever owned has had problems with one type of media or another. This is because the discs all have their own patented dye mixtures, and each is a little bit different.
I have problems using Memorex DVD-R discs on my Toshiba DVD recorder. The only drive I can get good results with Memorex DVD-R's is on my Memorex DVD drive.
For DVD-R media, I have had the best success with TDK DVD-R's.So far, they have worked on all my devices.
You may want to try DVD+R media. I use Memorex Lightscribe DVD+R and for dual layer recording, I use Ativa DVD+R DL discs, both of which have worked very well and I rarely have to throw one away.
It takes allot longer, but on my PC I always use the "verify" function to make sure I get a good copy.
Feb 17, 2011 | Samsung TS-H653F DVD±RW Dual Layer Burner
HP dvd640e not recognizing DVD+R DL
6/25/9:  While this external HP DVD640e burner was listed as a NEW drive - "new" meant never used. A check with HP techs told me the unit was a 2005 factory closeout and the dual layer disc required for it is a 2.4 speed disc. I bought a 2.4 speed DL disc and it works perfect in it.  As far as seeing a CD when a DVD was installed is presumed also the fault of having the wrong speed disc in it (that lot of Memorex DL discs I am also having trouble with elsewhere too). Double-checking my profiler, it does give speed as 2.4x as the burner's profile. Alas, the problem was my newness to the DVD technology. A slap to the forehead and move on.
Jun 19, 2009 | HP dvd640e DVD±RW Dual Layer Burner
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
What kind of dvds do i use for my memorex dual format dvd recorde
Look at front of it. It should say RW DVD + R DL or -R DL. That means you can use DVD+R discs or DVD-R disks 4.7 Gb (depends which logo you have). If its RW DVD RAM DL it can be any +R or -R. In addition you can use DVD+/- R DL (dual layer) disks with 8.5 Gb capasity. But the cost is at least 2 -3 times higher than regular DVD.
Good Luck
Dec 10, 2008 | Computers & Internet
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
