Question about Dometic Rooftop RV Air Conditioner
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
The AC (Duro Therm Model 620526.321) in my RV has been working great untill today. All of a sudden, the compressor would sound like it was kicking on, but then just hum for a few seconds, then kick off. When this occured, I can smell a slight electrical smell comming out of the AC vents in the celing. about 10 seconds after the compressor kicks off, it tries to kick on again and repeat the same cycle.
My trailer has two AC units, one works fine the other does not, so I know my shore power is good. I have also turned off the good unit to see if the power draw from both units might be causing a power droop in the bad unit. With the good one turned off the other one exhibits the same problem.
I am suspecting that my compressor is bad?
    Novelist:
  • 142 Answers
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Posted on Apr 16, 2008
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 90 Answers
Ya go with a new compressor
Posted on Aug 17, 2012
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
9/20/09 I just had the same problem with the same model
With rooftop air-conditioning units two issues are commons and that not clean unit that slow the fan and that effect the compressor, check the fan and see if the housing clean and no debris and as far as the compressor it is don and you need to replace it, I am sorry to tell you the news but on the other hand you can get used one now very cheep and they do work good. See if you contact local dealer that serves them and ask for used one or call campaign world and ask them to look for one for you…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Compresser will not kick in and there a electrical smell
Stop it!
Something has gone wrong and needs to be repaired. It's an electrical problem. The more you smell it, the more stuff is getting burnt. Take it apart and look inside it. Then restart it. The burning stuff will lead you to the bad part.
Jul 27, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,653 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
