I ordered the tv channel program from you 4/14/08 i am having a little problem with it sound and picture keep's breaking up i have the dial up system i tried another web site before i ordered this they told me that it would not work on dial up system so i think it is not going to work on this one so if this the case i would like a refund thank you fred seagle bibit global payment services user id-sleep password-daylight
    Scholar:
  • 176 Answers
Yes you need to return it because if you using dial up internet you cannot satisfied the output of the tv because of slow connection. If the company does not allow you return you better to upgrade your connection to the dsl to solve the problem
Posted on Apr 16, 2008
Recorded programmes from some channels break up- both the picture and sound- when replayed
I've got one. Does exactly the same thing. It usually happens within the first, say, 10 hours of recorded material. This is the most used part of the hard drive disc. We have 5-9 hours of programs we intend to keep so we end up re-recording over the next part of the disc repeatedly. This wears that part down. What I did was keep 2-3 hours of stuff in that zone and carried on recording and deleting as usual, as I still do. I'm watching it right now. But if I erase past the break 'zone', the recordings 'jump'. It has a big memory and shouldn't be a problem. So..........fill with programs to half the disc and record over the lesser used part of the disc.....it works for me. I'd be interested in hearing how you get on. Good luck Red.
Mar 04, 2015 | Humax PVR9300T HD DVR
My picture and keep on breaking up on some channel
If you have a good picture on some channels and the picture breaks up on others , it could be the input signal. What is the source of the input signal; i.e. cable, satellite, antenna???? Do you have a cable box? The problem may be with the box or with the provider's signal.
Mar 30, 2014 | Sony KDL-46S4100 46 in. LCD TV
Magnavox tv converter box some channels have no sound
When you program your HD converter, it searches for all available channels in your area and you may find, as I have, channels you never knew existed. As for the audio problem, some of the found channels may be so weak that all you get is the picture - no sound. You can delete the problem channels but they are likely to pop up again on your next programming run.
Feb 03, 2013 | Insignia Digital-to-Analog Converter for...
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Feb 20, 2008 | Televison & Video
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Computers & Internet Logo
David Payne
David Payne
