Question about Kicker DX350 Car Audio Amplifier
Kicker amp I have a kicker 1200.1 class d subwoofer amp and it is stuck in protection mode. What and how can i solve this
    New Friend:
  • 12 Answers
With this amp the main culprit is the Pulse width modulator i.c marked HIP4080, 9 times out of 10 replacing this cures the problem but may go again in the near future. If when removing the cover there are burn marks around the larger components around the edge of the printed circuit board then more involved problems exist! Thanks, acbva.
Posted on Nov 15, 2009
  • 975 Answers
If you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Posted on Apr 16, 2008
Would a Kicker DX250.1 250W 2-Ohm Mono Class D amp work well with a kicker dual 12" c12 subwoofer with 600watt peak?
you really want something closer to 600 watts. if you arent careful, you can overdrive the amp, since the speaker isnt seeming to mind the volume, and the resulting audio distortion can damage the speaker
Jun 19, 2015 | Kicker Car Audio & Video
I have 2 12" kicker solar baric squares L7 hooked up to a kicker cx 1200.1 amp as soon as I turn bass knob up it cuts out and amp goes into protective mode plus I have a 3 microfarad copasitor hooked up...
Sounds like your wiring is giving you the wrong impedance,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 22, 2014 | Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker l7 wanting to wire to best olm with hifonics 1200 mono
the best way to wire it is @ 1 ohm, but your amp has to be a 1 ohm stable amp. i'll attach some pics for you. this wiring depends on what ohm your subs are.
Option #2
2_2ohmdvc_2ohm.gif Wiring Option #3
2_2ohmdvc_8ohm.gif Option #2
Feb 26, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
2 12" kicker L7 subs. zx1500.1 amp. subs quit when i turn it up
It is possible that you are not providing enough current to the amp. It will go into protect mode if the current sags. What do you have running as a power cable. And also, your ground should be just as big and bonded very well to the body.
Apr 12, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
What amp size do I need
If the subs are going to be wired at 2 ohms you will need a class d amp that is 1200 watts at two ohms rms i would say you should probably be running zero gauge wire and at least a two fared cap
Feb 22, 2008 | Kicker S15L7 Car Subwoofer
Kicker solobarrick...still not working...
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker DX350 Car Audio Amplifier Logo
448 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
