Question about HP Office Equipment & Supplies
HP Toolbox Error Toolbox is not available because the printer Driver is not installed.
SOURCE: hp director
Issue
After installing Microsoft Internet Explorer 7 on the computer, the HP Director software window does not display when attempting to open the software.
Solution
The following solution works excellently for me. I had already tried updating drivers and re-installing the software but these steps had no result.
HP advises using the following workaround:
1.       Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2.       Press the Alt key and the Space bar together, and then select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar.
3.       Click HP Director on the Task Bar. The software opens and displays normally.
4.       Repeat Steps 1 through 3 every time the HP Director software is used.
NOTE: The HP Director window might appear a little smaller than normal, but the software is functional.
Posted on Oct 31, 2007
  • 141 Answers
SOURCE: I am not able to install toolbox of HP laser Jet 1320
bad disk.
Posted on Sep 17, 2008
  • 43 Answers
SOURCE: How do I install HP Toolbox for my HP LaserJet 3015?
connect both a parallel cable and the usb cable. That was the only way I could make a LJ 3030 to scan to PC.
Posted on Jan 23, 2009
leroyal
  • 2120 Answers
SOURCE: Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Posted on Feb 06, 2009
  • 956 Answers
SOURCE: Where do I find the HP 3030 Toolbox software ?
If memory serves me correct, your printer came/comes with two/three disc's. Each for diff prods.
Do you have the setup disc's. if so, load disc/menu/extra facilities to load.
If not, got to www.hp.com Find were to enter you printer details, you will be able to download updates, be patient, con tak a little time, a lot of bytes.
Good uck!
Posted on Nov 14, 2009
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
How do I disable HP ToolboxFX error alerts
how about installing a new laser jet HP printer tool box fx...
Jun 06, 2013 | Office Equipment & Supplies
I am able to install the printer getting hpqsclv.dll fastal error
this .dll file belongs to HP Digital Imaging Toolbox application i think if you go for costume installation you can get the option to not install the HP Digital Imaging Toolbox application ......try it........ best of luck ..........
Dec 10, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Hi. I have a HP Business Inkjet 1200. What to do to print a testing page? /Christer
Toolbox The Toolbox provides status and maintenance information about the printer. It also provides links to the onscreen user's guide for help in performing basic printing tasks and solving problems.
NOTE: The Toolbox is available for Windows computers only. If the Toolbox was not installed with the other printer software components, you can install it using the installation program on the Starter CD. To monitor a printer on a shared port (for example, \\portname\printername) from a client machine, the Toolbox must be running on the server machine as well as on the client machine. Opening the Toolbox
  1. From the Start menu at your computer, point to Programs .
  2. Point to the printer name, and then click the Toolbox icon.
Toolbox tabs The Toolbox contains tabs that you can use to view product information and change configuration settings. Tabs Contents Printer Status
  • Selected printer The drop-down list displays the currently selected printer.
  • Ink Level Information Shows estimated ink levels for each cartridge.
  • Order Supplies Provides access to a Web site where you can order printing supplies for the printer online.
  • Ink Cartridge Information Shows order numbers and expiration dates for the installed ink cartridges.
  • Preferences Gives you the ability to set advanced Toolbox settings, such as selecting which printer error messages appear, specifying whether you want to be notified by an audio alert when an error occurs, as well as the types of error messages that you want to see. Also, you can turn on myPrintMileage AutoSend, which provides you with a closer forecast of printer usage on the myPrintMileage Web site.
Information
  • Printer Information Provides links to myPrintMileage and shows the printer hardware and printhead health information. You can also use the tab to obtain information about accumulated ink and media use, statistics up to the last 20 jobs, and job tracking.
  • Help Information Provides links to HP Instant Support and HP Customer Support, as well as to the onscreen user's guide for help in performing tasks and troubleshooting. It also provides instructions that guide you through registering the printer onscreen.
Printer Services
  • Align Printheads Guides you through aligning the printheads.
  • Clean Printheads Guides you through cleaning the printheads.
  • Calibrate Color Allows you to calibrate color manually.
  • Print a Demo page Prints a demonstration page. This is used to verify that the printer is connected to the computer correctly and that the printer and printer software are working properly.
  • Advanced Configuration Allows you to set tray lock and select a default tray (if Tray 2 is installed).
Sep 08, 2009 | HP Office Equipment & Supplies
HP Inkjet toolbox utility error 1101
Uninstall all HP printer software from Control Panel, install latest drivers from their site.
Aug 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing problem
Turn off printer
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
HP LJ 3055 Toolbox Not Connected
Hi SaveWetland!
Without being able to see your machine, I'm going to make an educated guess at your problem. Many times, when a printer is used over a network, only the printer driver itself is actually installed on each user's machine. Utilities, such as the HP Toolbox, may not be installed. If your network administrator allows it, you could download and install the complete printer software package off the HP website, which I'm highly confident would solve your issue. If not, I'd advise you to contact your IT person and have him/her install the complete package for you.
Good luck and I hope this helps. Please let me know, and also provide a rating if you deem it appropriate.
Bob
Oct 15, 2008 | HP LaserJet 3055 All-In-One Printer
Canon Canoscan LIDE 30
For some reason, there are some HP model printer drivers that cause problems with the Copy function of the CanoScan Toolbox. Because of this conflict, when Toolbox Copy function connects with the printer driver, which is what it is doing when you select it from the dropdown. There had been some updates to the Toolbox software that corrected the issue. However, then HP release some new drivers for some models that reinstated the issue.
So the first thing to try would be to download and install the most current version of Toolbox for your scanner model (ver. 4.1.3.5).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
If the problem isn't corrected with that, then you won't be able to use the COPY function unless HP updates there printer driver to correct the issue. If you really must have the COPY option, then you might try using a older Toolbox just for that feature. If that is a consideration, then get the Toolbox ver 2.2.3 from the CanoScan N650U download page.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6858
The COPY function from this version should work fine with the HP printers.
Good Luck.
Apr 28, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
HP deskjet 5550 sometimes prints and icon reads Toolbox not available because printdriver is not installed
thats easy! HP has a bad habit of screwing drivers up! List here what operating system you have, and the exact,with any letters behind the 5550, model number here and I'll get the drivers. I have almost every drivers for windows for that particular printer
Jun 13, 2007 | HP DeskJet 5550 InkJet Printer
963 people viewed this question
Ben Johnson
