I HAVE A DVP3005K/75 PLAYER AND I HAVE BEEN GIVEN SOME REGION 1 DVD,S THEY WILL NOT PLAY, I WAS TOLD THAT I COULD GET A CODE TO UNLOCK THE PLAYER SO I COULD PLAY ANY DVD. CAN YOU HELP. THANKS
  • Davidrj Jan 10, 2009
    Yes, it seems that if you press System Menu and move to "Preference Page and then enter 135566 and change the region to "0" it will play, HOWEVER, on the DVP3005K the System menu key does not open a Preference page" can anyone assist?
I have the DVP3005/05 and I noticed that the preference page can not be accessed while a DVD is still in the machine ! and according to the DVP3005K/75 manual it does have a preference page, so you must still of had a DVD in the machine when you tried to access the preference page, as this locks it out, eject the DVD and you should then be able to access the preference page and enter the unlock code.
Posted on Mar 11, 2009
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Region 1 codes
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Aug 11, 2008 | Televison & Video
Dvd player DVP 3144/75 only play some dvd how can I program to play ALL4 region?
you will have to unlock the player to play all the region codes sir.
Aug 01, 2008 | Televison & Video
HELP
You can try this one:
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting.
Jul 20, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Unlock region codes
1. Open DVD tray
2. Press the '0' key on the remote three times, waiting about one second
between key presses. The 'Region Test' screen will appear on the TV. If you don't
get this screen, then power off/power on again and start over.
3. If the Region Test screen appears, enter '0' for all-regions.
4. Press pause to save and exit.
May 25, 2008 | Televison & Video
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
Toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
Jan 19, 2008 | Toshiba HD-A30 HD-DVD Player
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Nov 18, 2007 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
