Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Bosch dishwasher e14 fault code
Fills then check water light lights drains then e14 code
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
  • 25 Answers
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
Posted on Jan 25, 2008
  • 236 Answers
SOURCE: BOSCH DISHWASHER SMS63E09GB FLASHING E 15 CHECK WATER
it may be either the water meter tank on the l/h side or front water feed hose is blocked with food debris.
Posted on Mar 13, 2009
  • 423 Answers
SOURCE: LG 6810ST Dishwasher- OE Error Code
SInce the drain hose is not plugged or kinked, the next step if to remove the filter that is beneath the lower rack done in the sump area. Remove approximately 10 phillips screws.
Inspect for debris in the mesh filter and underneath it, especially the drain outlet.
Reassemble and retest with a quick cycle.
If problems persist, suspect a failing pump motor. Schedule professional repair is recommended.
Posted on Mar 30, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Bosch hot water error 14
hi julia
after checking on your bosch water heater error code e14
you can try to reboot your system but if code comes back you may need to find a plumber that knows your system to fix your fan system and clear your fault code. this is the site i got info from
http://www.jimsplumbing.net.au/bosch-hot-water-system/troubleshooting-guide/error-code-e14/
p.s. this site is not in the usa
May 20, 2018 | Bosch Water Heaters
My bosch dishwasher stop working after a few minutes and showing E14, Check water and rinse red lights on. What's the problem?
It is not the drain.
You have to close the door tight.
Push it in
It will start with no error E24
Posted on Jun 27, 2017
Jun 20, 2017 | Bosch Dishwashers
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Siemens faults
Assuming the inlet valve and hose and supply is OK and its filling with water....e14 is..
Flow fault or flow sensor fault, could be a poor connection on the sensor to the water matrix or less likely a blockage in the matrix.
Also check all inner for cleanliness and debris.
Aug 06, 2014 | Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Check water light on my boach dishwasher
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left. Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Feb 20, 2013 | Bosch Dishwashers
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
5,852 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
