Question about Zebra 105Se Thermal Printer
Serial Settings for the Zebra 105Se
We have an used Zebra 105Se with only the Serial port on back (25 pin Serial connector). A couple of questions... do we need a null modem cable? or is there a means for using the dip switches (bank 1 and 2) to allow a standard modem cable to work?
Tom
Here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Posted on May 20, 2008
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
My zebra 105Se keeps printing blank labels.
Do the labels come out right when you print locally? That is the first thing to see. Serial devices over a network are tricky. Baud rate and what to do with CR LF, stop bits, parity etc. need to be right.
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
My zebra 105 se wont print using RS232 serial cable
Make sure the serial dip switch settings match your com port on the computer. You need a null modem cable or adapter.
Mar 04, 2011 | Zebra 105Se Thermal Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
We are trying to set up to run locally on a serial port
The serial port parameters are set from the front panel.
Hit the "Setup" button, then hit the "Next" button (many times) until you reach the Serial Port parameters. You'll be prompted for a password before you get there. The default is "1234", entered with the "Plus and Minus" buttons.
Use the "Plus" and "Minus" button to make changes.
When finished, use the "Exit" button. Select "Permanent" changes and hit the "Save" button.
Sep 27, 2007 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
717 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
