Trying to update pass word this return status indicate that the value provided as the current pass word is not correct.
    Scholar:
  • 176 Answers
Maybe you entered the value that the windows cannot accept it. For example the *, or / try to put a password in a plain word only
Posted on Apr 16, 2008
I have HP Color LaserJet CP1515n Printer wanted to configure on domain base network . Just need to know the IP address of this printer????
Status TheStatusfolder contains links to the following main pages.
  • Device Status. This page indicates product conditions such as a jam or an empty tray. After you correct a problem, clickRefresh statusto update the product status.
  • Supplies Status. View details such as the estimated percent of toner remaining in the print cartridge and the number of pages that have been printed with the current print cartridges. This page also has links for ordering supplies and for finding recycling information.
  • Device Configuration. View a detailed description of the current product configuration, including the amount of memory installed and whether optional trays are installed.
  • Network Summary. View a detailed description of the current network configuration, including the IP address and network status.
  • Print Info Pages. Print the Configuration page and other information pages, such as the Supplies status page.
Dec 13, 2014 | HP Office Equipment & Supplies
Waher shows c1 what is my problem
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
If that does not help then, "C1 = Average current limit Or Instantaneous current limit."
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps at the motor windings
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
HP - Compaq 6310P Laptop that Is giving an Isass.exe system error
As you may know, lsass is; Local Security Authentication Server. ANY OF THESE THINGS CAN RESULT IN AN UNUSABLE SYSTEM! So don't try them if you aren't able to re-install your operating system without trashing it (Over top should work), if there's any information not backed up that you can't lose, or aren't prepared for the worst, because that's what usually happens, right? :^D TAKE IT TO SOMEONE IF ANY OF THESE THINGS APPLY TO YOU.
Although you shouldn't have any problems with these simple remedies, I don't want to be responsible if it does!
The trojan you found and removed has corrupted some registry settings.
If you have a known good configuration, you can "go back". OR you can try running a registry cleaner on it.
You can also try going into "Services" and killing it, which should bring up your Welcome screen and reboot. All of your usernames and passwords may be gone though! And you'll have to start over.
GL!
Sep 02, 2009 | Computers & Internet
Count number of Delivery Status
To count textual values, use the countif function; the syntax is =countif(range,criteria). So, if your range, for example is B3 through B100 and you want to know how many cells contain the status value Delivered, put the following in the cell you want the count to show: =countif(b3:b100, "Delivered"). Do the same thing for each of your other status values in the cell that you want the count to appear.
Note that this requires each status value to be spelled correctly in each cell. I'd recommend assigning shorter values, say 1 through 5 or A through E to avoid that -- unless the values are being generated automatically so the spelling is guaranteed correct.
Jun 18, 2009 | Microsoft Excel for PC
Unable to boot xp system
If you can install a second drive there is an option, otherwise you will have to reinstall windows.
Apr 27, 2009 | Dell Dimension E520 PC Desktop
My computer wont exit reset status mode!
I need some help. I just bought a new hp netbook, but when I try to turn it on.....all I get is a small box saying: When trying to update a password, this indicates that the value provided as the current password is not correct.
What does this mean, I tried to reboot and everything but nothing happens, the computer keep restarting and I keep getting the same small box.
Please need some advice and help
Apr 11, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
C46 appeared on my toshiba e-studio 550 copier
C46 indicates Abnormal pressure roller thermistor during a ready state.
Perform following inspection:
1.. Clear the status counter.
Change the current status counter value (08-400) “3” or “8” to “0”.
If happen again, perform following inspection:
1. Check the pressure roller thermistor.
(1) Check if the connector is not disconnected.
(2) Check if the pressure roller thermistor closely touches the surface of the pressure roller.
(3) Check if the harness of the pressure roller thermistor is not open-circuited.
2. Check the LGC board.
(1) Check if the connector J334 is not disconnected.
(2) Check if the conductor pattern on the LGC board is not short- or open-circuited.
(3) Replace the LGC board.
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Emachines T1090
Put the MS Windows CD in the drive, restart the computer and make sure it's booting from the CD, then make a repair installation.
May 05, 2008 | E-Machines eMachines Desktop PC
MSI RG60G : Firmware upgrade failed or ROM not burn in flash completely
Did the firmware install completely, or did the download get interrupted?
In the manual it should tell you how to log into the router. Have you tried doing so?
If the download was interrupted then you have a corrupt version of firmware that leaves your router inoperable. The only way to correct this is to reinstall the firmware.
Mar 09, 2008 | MSI Wireless-G RG54G3 Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
