Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
SDM-HS73P Screen Flashes
By Wasga on Apr 16, 2008
The screen on my monitor flashes on and off. The power light stays green but the screen will come on for about 1 second and then go out for roughly 2 seconds. I can see my desktop perfectly when it is on. When I unplug the vga cable, the monitor displays check cable untill it sleeps. Any Ideas?
Comments:
Apr 16, 2008
- That makes sense. The power seems to be good. The voltages are correct and there are no fluxuations. I saved this monitor from going into the trash so it doesn't have to be fixed. How much do you think the part would cost?
Best Solution
posted on Apr 16, 2008
Very Helpful)
Mark_Webber
Rank: Wiz
Rating: 85%, 384 votes
This is a problem I have seen with a few LG monitors.
Your Inverter circuit is fine (that powers the lights to your screen so you can see the image on the LCD panel) but the monitor does not like having a video signal attached to it.
  1. Bad capacitors on the power board can upset the current going to the controller board. This board included the video input circuit and the power supply needs to be stable for this to operate.
  2. The controller IC that translates the video signal into what the LCD panel controller can understand is failing. Normally this fault occurs in the horizontal and vertical input of the IC. The fact you can see the other message on screen is due to it going through it's own internal and seperate section of the IC. In this case the only repair option is to replace the internal video board. Sony will not supply the parts directly to the public, but if you are really nice, they "may" tell you where to get one externally to Sony.
Hope that helps =)
Comments:
Apr 16, 2008
- In general, Sony will have an authorised repair centre close to you. It will be just a normal TV shop that does their work.
The part would need to be ordered in by the shop through Sony and would take 1-2 weeks depending work load of Sony spare parts and also the TV shop to have it back.
Cost wise, the card would be around $70 Australian and then labor on that. This is not a hard process for the shop. Just open it up, old card out, new card in, test it, close it back up.
If you take it to the shop first, they may even find it is just those capacitors causing the problem and then replace those in no time at all. You will save on the part, but the labor cost will be higher since they have to do more manually.
The first thing to do before you goto any shop is contact Sony either via email (check the support section) or by phone. Your LCD may even still be under warranty, and will cost nothing.
Be ready if you call them with the model number, serial number and purchase date if you remember. The serial number is the all importnat one though. They will be able to tell from that if it is still within the warranty period.
Was this helpful?
Yes
No
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
