Question about Samsung Televison & Video
Samsung hlp5085wx/xaa make loud noise when turn on
BMW Rider
  • 232 Answers
SOURCE: Samsung DLP HLN5065WX/XAA
krugie, get it replaced now or the lamp will burn up, be advised that they are expensive to get replaced, not an easy job to do, fix it now or pay much more later is the best advice I can give you, good luck, BMW Rider
Posted on Dec 28, 2007
SOURCE: Samsung HLP5085wx/xaa
i have Samsung HLP5085WX 50" Projection TV
that occasionally turns its self off and then back on again does anyone have any idea what could be causing this
Posted on Aug 31, 2009
  • 178 Answers
SOURCE: Samsung DLP HLR5667wx/xaa. All sudden loud noise non stop
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set.
Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
Posted on Sep 05, 2009
circuitworld
  • 335 Answers
SOURCE: samsung tv hlp 5663wx/xaa
You need to change the color wheel, if you want a temporary fix use WD-40 on the wheel bearings. This will stop the noise for a month or two....... but eventually you will need a new wheel then go to service mode and align the colors under 'index delay'..........
Posted on Nov 04, 2009
  • 418 Answers
SOURCE: Samsung HLP5063WX/XAA 50
Bad color wheel.
Posted on May 02, 2010
Testimonial: "Diagnosis was on the money, ordered the color wheel on-line and installed it myself. TV is as good as new. Thanks!"
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
How do i fix my color on my projection tv samsung hlr5677 everything else is fine just made loud noise and then color was gone
Remove the lamp and look where it faces---the color wheel is there and you need to carefully look at it to see if any of the plastic segments are missing or it is broken.
If even one tiny part of the wheel is gone it can cause this.
May 30, 2012 | Philips Samsung HL-R5677WX/XAA...
I have a Samsung HLT6187SAX/XAA making a loud air noise, picture is good but making noise
This noise may be coming from a Fan that's about to give up.
www.aaatvservice.com
May 24, 2012 | Samsung HLT6187SAX 61" DLP HDTV
Why do i hear a fan noise when i turn on my samsung dlp4663wx/xaa?
Hi, there are fans inside your set to cool the lamp and the dmd section of the light engine, if they are objectionally loud then the "loud" one needs to be replaced, if you are just hearing a fan sound standing next to your set or just after you turn set off, that is normal and nothing to be concerned about, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Nov 02, 2008 | Televison & Video
Televison & Video Logo
237 people viewed this question
Jerry Greenberg
Jerry Greenberg
