Question about Garmin iQue M5 GPS Receiver
Cant figure out how to use navigation
How do i plot a course on navigation
Click the q button on the bottom right until you see plan a new route....then it'll ask you to choose from current location, or map, or FIND....
Mine's broken now ...but that's how...
Posted on Jun 13, 2008
How to do locus
On a piece of graph paper plot the path of a point which satisfies the given condition or equation always. For instance if the condition is 2x+y=0 you can substitute a series of x values and figure out y for each, and plot those points. The locus will be the line joining those points.
Dec 18, 2013 | Computers & Internet
How should I set my ti 83 plus for my statistics course? I keep trying to sort L1 in ascending order and every time I get ERR: INVALID DIM 1: QUIT ...
If some of the lists are missing press the STAT button then select SetUpEditor and ENTER to restore all of them (without data, of course.)
If the statistical plots are turned OFF you can turn one of them back ON again. Press SHIFT Y1= to access STAT PLOTS. Press 4:Plots Off. A good habit to avoid problems. After you turn all plots OFF, you must turn one of them ON if you intend to draw statistical graphs. You can for example Turn Plot1 ON.
  1. To do so Press SHIFT Y1=, select say 1:Plot 1 ENTER.
  2. Highlight ON and press ENTER.
  3. Press DownArrow to move to line TYPE
  4. Then you can set the plot type. You have 6 choices. Use the left/Right arrows to select one of the 6. The selected plot type icon will remain highlighted when cursor is moved.
  5. Use DownArrow to move to XLIST line and select the x-values LIST. etc.
  6. When finished Press 2nd QUIT to exit the stat plts configuration settings.
One statistical value that may be of interest to you is the R, R^2 coefficients. To have it displayed (if the regression model has it), you must set DiagnosticsON.
Press SHIFT 0 to enter catalog. Press x^-1 key to jump to the first command that starts with D.
Scroll down to reach DiagnosticsON, highlight it and press ENTER then ENTER.
Sep 16, 2011 | Texas Instruments TI-83 Plus Calculator
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
I am trying to find the domain and range of a function on my TI 84 plus but it keeps saying dim mismatch HELP
Go to Y= and you will see Plot 1, Plot 2 and Plot 3 at the top of the screen. One of these is highlighted. Navigate the cursor to the highlighted option(s) and press Enter to deselect it.
This error happens when you are trying to graph data in a list and the lists are either empty or not the same length.
Jan 31, 2011 | Texas Instruments TI-84 Plus Calculator
Invalid dim message? Trying to plot a histogram. All plots except Plot 1 are turned off. Cannot seem to figure out what is wrong.
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jan 27, 2011 | Texas Instruments TI-84 Plus Silver...
Everytime i try to graph something, it says error: invalid dimensions. I cant figure it out! can you tell me what to do?
Aug 30, 2010 | Texas Instruments TI-83 Plus Calculator
I have accidenty changed my language settings, how do i change it back to english?
Go into your manual, and figure out how to navigate to the language menu, then change it there. If you can't figure it out from the menu, try to find a similar camera and use it to go step by step to the language menu, where you will change the option to English. Otherwise, take a language course at your local college!
Feb 17, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
How do i turn on the phone system on my 03 navigator.
In order to get step by step instructions I would recommend your owner manual. Other than that, mose phone systems connect through bluetooth and there should be a "connect" button. Or, check your cell phone's bluetooth device and select "search" to see if you can connect to your vehicle.
Hope this helps
Jul 30, 2009 | 2000 Lincoln Navigator
How do you change the backup light
open tailgate and look for 2 screws in between light fixture and tailgate. remove two screws and take entire light assembly out to access light-bulbs.
Apr 21, 2009 | 2001 Lincoln Navigator
Garmin iQue  M5 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
