When I turn on my Pioneer Pro-Elite 530HD, it stays on for a few seconds, then automatically shuts off, then turns on, then turns off...again and again until I manually shut it off. It's like a breaker or something...do you know what is going on?
  • kenoliver Apr 22, 2008
    I get a great picture for awhile, then it will randomly go in standby for a few seconds, then come on by itself (great picture again), but then it repeats this over and over until I completely shut the TV off.
    I thought I would give you a little more detail, as it doesn't appear to be a shutdown mechanism (at least I wouldn't think so if it's turning the TV back on by itself). The problem is that it's just going into standby, then on, then into standby, then on, etc.
    Any ideas what it could be?
  • kenoliver Apr 28, 2008
    had service guy come out. He worked with Pioneer and came up with UCOM video assembly replacement. We are waiting on the part...thanks to everyone for your suggestions.
  • 19,396 Answers
All modern TV set have a protective switch that turn them off when a short or an over voltage is detected. If the switch is turning your device off it is better to have it fixed, if you keep trying to restart it to many times you can damge your tv.
Posted on Apr 17, 2008
  • 3,037 Answers
Your set was going into protective shutdown. Probably a leaky diode that was raising voltage that triggered the shutdown circuitry.
Please check this out and let me know if you need any further help
Thank you for using Fixya and Have a Good Day
Posted on Apr 16, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    Were you able to get this working, if not please let me know otherwise
    I would appreciate it very much if you could rate this solution
    Thank you
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    I think it might be the lamps then,
    The first thing you can try is to remove them and see if they look clean and then put them back in
    If that solves it Great! If not, they and the ballast would be the first things to get replaced
  • Benjamin Patri
    Benjamin Patri Apr 28, 2008
    no problem, glad you were able to figure it out
    Scholar:
  • 170 Answers
You have a short. i would start by unsoldering the convergance ic's or unpluggin the board if it is by itself and try it on again, if it comes on then replace all conv ic's and check resisters. if this does not fix your problem then check vertical ic for cracks, solder it anyways.
then check h-output for cracks, its a transister on a heat sync next the the high voltage transformer. if that doesn't get you goin, check all fuses again, check for raised caps in p/s. also check for b+goin to HVT durring turn on.
  • Scott Henderson
    Scott Henderson Apr 16, 2008
    convergance ic's are usually in the front on these. and may only be one big ic. but since this is a newer set they have prob gone away from the monster single ic. so should be 2 or 3 big ic's mounted on big heat sync's. good luck
  • Scott Henderson
    Scott Henderson Apr 28, 2008
    ok please let us know if you can what replaces fixes it.
    maybe cost more with less headache.
NEED OPERATING MANUAL FOR PIONEER ELITE PRO 530 HD TV
both may be a little hard to find anymore, the main problem is dead set and that is bad soldering all over the giant power supply board this set uses.
Sep 02, 2012 | Pioneer PRO-530HD 53" Rear Projection...
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
