Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio cycle stops and flashes LF
  • Anonymous Apr 26, 2008
    when washer is filling LF flashes but after 3 times of pausing then starting machine it will continue as usual.
I also had this problem. After numerous restarts and troubleshooting I finally realized the problem....my floodsafe burst-proof supply hoses. They are equipped with a shut off valve which will activate if there is an "irregular" flow of water. I guess mine finally went bad. After resetting the valve in the hose several times, I simply replaced the hose with a standard reinforced hose and the washer worked perfectly.
Posted on Sep 16, 2009
    Problem Solver:
  • 7 Answers
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Posted on Mar 19, 2009
    Genius:
  • 1,028 Answers
Check hoses and screens make sure water flow to machine is on all the way and hoses not reversed ..last resort main fill valve has bad coil on one of the valves
Posted on Apr 19, 2008
Whirlpool cabrio LF flash
Posted on Jan 16, 2009
3 Suggested Answers
  • 132 Answers
SOURCE: Whirlpool Cabrio is flashing a LF code and all the
You may have accidentally put the machine in demo mode or one of the test modes in diagnostics. Try unplugging unit for a couple of minutes and restarting to reset board. It may be something else more serious, or difficult to find, but it cost nothing to try.....
good luck
Posted on Mar 22, 2010
  • 572 Answers
SOURCE: I just tryed to do a load with my Whirlpool Cabrio
long fill. check and clean your inlet screens
Posted on Feb 06, 2010
My whirlpool cabrio is reading LF and F1
Your Cabrio is continuing to fill (Long Fill) past the set limit, causing a Flooding potential.
Oct 05, 2016 | Whirlpool Washing Machines
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,070 people viewed this question
Dan Webster
Dan Webster
Sal De
