Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Format error c:13:01 showing on
By johndryburgh on Apr 16, 2008
format error c:13:01 showing on screen of sony cybershot dsc w55
Same Problem
Mar 29, 2009
-   while taking photos this format error C:13:01 appears, if you turn off the camera and switch it on again the fault disappears but any photos taken after this point cannot be downloaded from camera.
-   Guest
Feb 14, 2009
-   Hello, I have a Sony Cybershot DSC S85. Suddenly it started to show this Format Error C:13:01 and it is not working any more. I thought it was the memory card but it is the camera cos I have tried with severals and all the time appears the same message. Is there anything I can do to solve it? Thanks-   hiquetal
Oct 30, 2008
-   Getting C:13:01 "Re-insert Memory stick" when insert the Memory stick PRO Duo.When I took it to Sony service centre,I was told that it cannot be repaired.Please help me to resolve this error.-   Guest
Oct 18, 2008
-   I have a MVC FD90 and I try to use it it runs like it wants to record on the floppy, but it then come up with that error c:13:01! What gives I have tried formating the floppy and nothing works! I have had this camera since 2000 and carry it with me hunting and fishing. Any ideas???-   murdam564
Aug 13, 2008
-   Having the same C:13:01 error on my DSC-F707. I was able to put the Sony 128mb memory stick in my Epson printer and recovered the pictures which leads me to believe that it might be an issue with the camera. So I called CSI camera repair in St. Louis and he said that it is most likely the circuit board that holds the memory stick reader and he would not do the work himself he would have to ship it out and it would cost about $200 to repair. So I guess I will be looking for a new camera.-   gorzie
Best Solution
posted on Jun 26, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
no it was nt helpfull in our case. as we have remover external memory card. reformated the apparatus & started again.
now we r using only its internal memory. it means problem was with external memmory card.
Good Luck.
Solution #2
posted on Aug 29, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i got this error and all i did was went into the camera settings and reformatted the memory stick lot everything on it but i was lucky i had taken everything of it already
Solution #3
posted on Jun 01, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
We are finding that larger than the 256M doesn't work on this camera. If you have the error c:13:01 on a 256M or smaller, put it in the camera and format the disk from the camera. Put the camera in setup up mode ( on the knob) scroll down from camera set up to set up 1. Format is 1st selection, Go to Ok, Go to Ok. This should solve the problem. Hope this helps!
Solution #4
posted on Nov 29, 2009
Not Rated)
zVideoguy
Rank: Apprentice
Rating: 0%, 0 votes
Solved it by accident! Went to "set-up/file number/reset" after resetting I then formatted stick and now it worky... Sony dsc-f707 camera w/ 128m stick
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
canon powershot a410 doesn't take pictures and when you try to turn it on while the wheel is on... (More)
Answer
I have a cx7430, which I love. It seems that the sensor is faulty. What is approximate cost to... (More)
Answer
After taking several pictures in Program mode, my 30D locks up and won't take pictures. "One... (More)
10 Other Users Have The Same Problem - Continued
Comment by callumgrant7, posted on Jul 08, 2008
same has happened to me, think its the memory card, anyone manage to save any pics?
Comment by Guest, posted on Jul 01, 2008
I too am getting the same thing...FORMAT ERROR then a C 13:01 blinking in the upper right hand corner.
Comment by kjwright23, posted on Jun 03, 2008
Ditto I have the same issue - even happens when I choose "set up".
Comment by mmkhere, posted on May 08, 2008
hi ,, when i insert my 2gb memory stick inside my sony s750 i get an error message as "FORMAT ERROR" it also displays c 13:01 error. what shall i do . please help me out.......
Comment by hope15, posted on Apr 24, 2008
When i turn on my camera, it says "acess" for a while and then switches to "Format Error c:13:01" I have no idea what this means or what to do about it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
