Question about Pioneer Audio Players & Recorders
Gm-x304 bridgable amp. Im trying to hook that up to 1 12" sub also I cant get the sub to power on. Do you need to hook up the remote off cable to make it power on? So how would I plug the wires for the sub in if I dont have a wire harness. Or where could I find a wire harness for this sub?
SOURCE: two amp
my peavey is set at max,my subs are 2ohm so my amp will is set at 2ohm...
if i had 2 power amps,why would one sound louder then the other?
Posted on Feb 29, 2008
  • 151 Answers
SOURCE: How do I hook up my 2 outdoor speakers to a Denon 3805.....P.S no remote
PUT YOUR OUTDOOR SPEAKERS INTO SURROUND BACK SPEAKER "PORTS"AS YOU CALL THEM GEMMEG THEN GO TO UR SET UP MENU AND SWITCH ON ZONE 2 OR IT MAY BE AS SIMPLE AS A SWITCH ON THE FRONT OF YOUR AMP.IFF YOU STILL HAVE NO SOUND YOU MAY HAVE 2 TURN THE VOLUME UP FOR ZONE 2.ALSO SOME AMP NEED TO HAVE THE SOURCE ; IE WHAT U WANT 2 PLAY INTO ZONE 2 FOR EXAMPLE YOUR CD PLAYER.HOPE THIS HELPS ,IFF NOT GET BACK 2 ME 2 C IFF I CAN DO ANYTHING ELSE.
Posted on May 20, 2008
  • 4 Answers
SOURCE: remote wire
there should be a remote wire for your amplifier on the back of your stereo if you have an aftermarket stereo. It's usually a blue wire, if not you can always hook it to the same remote wire as the one your stereo is running off of.
Posted on Dec 10, 2008
LVT7857
  • 116 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
zenglish87
  • 5 Answers
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
Amp has power but sub won't play
The system control is just a fancy name for Remote Turn On. It is usually blue on the back of most decks.
Nov 24, 2013 | Pioneer GM-5100T Car Audio Amplifier
Im trying to hook up my subs to this headunit but i cant get the power from it to the amp. The amp is good and the subs are good
have you got a wiring kit for the amp? the amp needs atleast an 8 guage tho id suggest a 4 guage running from the batter to the amp with a 50 to 80 amp fuse atleast, then it needs to be ground to the chassis. a remote wire then needs to be run from the back of the headunit so that the amp only turns on when the ignition is on, then hook the wires from the amp to the sub.
Jun 23, 2010 | Legacy LD32MUB Car DVD Player
Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Oct 11, 2009 | Car Audio & Video
Car subwoofer problems
The cable should not cause the problem unless it is shorting out somewhere on the remote or positive cable. I would use a larger gauge wire first as this is the cheaper way to go, and if the same problem occurs you are having a short in the sub or box causing the protection mode. You will have to back trace to find possible cross connections.
Jun 21, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Fuze blowing
try: a shorter ground cable, a bigger ground cable or sanding the surface where you make your ground. a lot of amps will tell you the ground should be no more than 3 ft and for any the shorter the better
Apr 27, 2009 | Pyramid PB1281X Car Audio Amplifier
Troubleshooting amp setup
You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
Jan 05, 2009 | Car Audio & Video
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Witch is better
hi there. ill start with the wiring. you should have a blue remote lead going to the back of your head unit, the power cable running straight from the amp to the battry, the earth should be earthed in a fairly decent place, any metal inside the car realy, and then your wires pos and neg from the amp to the subs. the reason why the kenwood might not have much base on it is to my knowledge, there should be a switch somewhere on the amp that will increase or decrease the power input for the speakers, if this is set very low then hense why theres not much base comming from them. if the amp is on and its giving something to the subs it probably isnt the wiring. try checking the amp for the switch first, if you cant find it try the pioneer amp and see if theres any diference.
dont hesitate to contact me if you get stuck
cheers, adam
Oct 31, 2007 | Pioneer GM-7200M Car Audio Amplifier
552 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
