2wire (1000-400108-001) Router Logo
Anonymous Posted on Apr 15, 2008
2Wire to connect to a VPN far away.....
Hello, I read your instructions. The VPN Server does not sit her on my network, it is far away, and I am unable to access it. When I click on the VPN icon on my desktop that has been pre-configured it doesn't help me connect.
However, I cannot seem to find a way to allow the VPN through the 2wire.
Anonymous
Level 1:
Scholar:
  • Contributor 53 Answers
  • Posted on Apr 17, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
53
Questions
0
Helped
50030
Points
98
Were you able to use DMZPlus mode in your 2wire modem?
also check if your computer is able to access the internet & you have not hard coded your IPs in your LAN (if you are using dynamic IP).
How connect cisco 5015 vpn with barracuda linkbalancer 330
Your Internet gateway <--- primary router
Port #1 on primary router <---> VPN server
Port #2 on primary router <--> Load Balancer
Load Balancer <--> web-server #1
Load Balancer <--> web-server #2
Load Balancer <--> web-server #3
VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
1helpful
2answers
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
tip
VPN and IPAD
So far the <b>iPad </b>has been a great hit in our home. From <i>remote access</i>, browsing the web, email and movies. I have only good things to say about this device.<br /> <br /> The <b>iPad</b> supports a <b>VPN connection</b>. To configure it.<br /> <br /> Go To <b>Settings</b>, Then <b>General,</b> <b>Network</b>. <b>Select The VPN</b> And Move The <b>Slider To On</b>, Then <b>Add A VPN Configuration</b> With Your Server And <b>Account Information</b>.
on Dec 20, 2010 • Cell Phones
Frequent VPN connection drop on my wifi
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
7helpful
4answers
I bought an unlocked G1, Im in the UAE, how can I set up my phone it is not connecting to the 3G network of etisalat
Here is how to set G1 3G and MMS for UAE Etisalat separately (u can enjoy mms or 3G alone by deactivating settings for either one). First you need to setup 1 access point for each service, sttings is as follows:
-----------------3G----------------
Name: Etisalat3G (could chos any name)
APN: Etisalat.ae
MCC: 424
MNC: 02
APN type: default
--------------------------MMS----------------------
Name: EtisalatMMS (chose any name)
APN: mms
Proxy: 010.012.000.030
Port: 8080
Username: mms
Password: mms
MMSC: http://mms/servlets/mms
MMS proxy: 010.012.000.030
MMS Port: 8080
MCC: 424
MNC: 02
APN type: mms
Enjoy the ultimate G1 services!!!
3helpful
2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
