Question about RCA HD50LPW42 50" Rear Projection HDTV
Bad Colorwheel I need the procedure to change the colorwheel
  • Kell188 Apr 17, 2008
    I installed the color wheel. A little nerve wracking, but all in all quit do-able. The color wheel wasn't exactly like the original. Had a ribbon wire instead of standard wires and the three torx screws holding the color wheel to its mounting plate were larger. I would think this will improve the bearing performance, by reducing vibration as the wheel spins.
    Looking around in the back of the TV. I don't think these things are getting enough air circulating around in there. I saw the cheap fan, and its position doesn't give it much room to circulate air. I'm wondering if these TV's suffer from getting too hot! Thus the bulb and colorwheels are failing from heat damage. I'm going to place a fan behind the TV to circulate more air.
    Scholar:
  • 170 Answers
Take off the back of the set. look for the lamp area. to the left of that should be the color wheel. please note you may have to remove the light engine from the set to get to the screws. there should be 2 screws on the color wheel. on some sets the top comes away from the bottom half of the set and you maybe able to remove it that way as well without removing the light engine.
becarefull with the wire and connector goin to the color wheel as it maybe a small ribon cable. if you unplug any connectors they should be easy to remember where they go.
good luck if you need more let me know as i have done tons of these.
Posted on Apr 16, 2008
  • Scott Henderson
    Scott Henderson Apr 18, 2008
    the color wheel could be damaged by heat if your vents get blocked by dust or dirt. you need to keep vents clean. also if you smoke around your set it could get sucked into the light engine and it will start causing your picture to go dark. keeping the bulb cool is a good thing, this will extend the life of it. also turning it on for a couple of hours is better then turning it off after 30 and goin to the store and comming back 15 minutes later to turn it back on to finish your program. its better to leave it run as turning it off and on also takes from the life from it.
    Master:
  • 555 Answers
Yes, it is possible to change a color wheel yourself, if you are very mechanically adept. It is easy to get to this light engine, once you get the back cover off the set. It takes a very small torx screwdriver and the color wheel itself is fragile. All that said, I still don't recommend it for most consumers, because it goes a lot smoother when done by an experienced tech.
Green light flashing, bulb will not turn on, green light sometimes goes to red flashing light
check the lamp. does it have bulges, black spots, flaking or fogging? if so replace it. aslo if the screen on the side is clogged with dust. if the lamp is ok, check the colorwheel. if you don't hear a high-pitched whir when you turn it on, the colorwheel motor is bad. replace the colorwheel. check the fans, too.
Mar 23, 2010 | InFocus X1 Multimedia Projector
The picture come on then goes black and then the television turns off. I thought it might be a bulb problem (4 years old). So I bought a new bulb, seemed to work and then began to go black again with all 3...
when the colorwheels start to go bad this is the symtom that shows up. try this listen carefully to the rear of the tv near the lamp door. as you turn off the tv if you hear a slight grinding noise as the colorwheel slows down that means the bearings inside the colorwheel are dry and you will need to replace the colorwheel.
Mar 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Will not turn on, red light flashing next to the menu button
if the fans don't turn on, they may be bad and needs replacing or rewired. if the fans turn on but not the lamp, the colorwheel may be bad (listen for a high-pitched whir when you switch it on. if no whir, replace the colorwheel). if the colorwheel is ok, replace the lamp.
Mar 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
After it warms up color goes to green and red
DLP TVs have color created by optical block or colorwheel. Colorwheel bad will make whining noise. This needs professional repairs. Check it out at www.fixurtvs.com.
Feb 22, 2010 | Vivitek V37655 56" DLP TV
The blue lights come on but the screen does not come on, what can i do to fix that?
if you do not hear a high-pitched whir or a loud buzzing when you start it up, you have a bad colorwheel. if the colorwheel is bad, the lamp won't light. if the colorwheel and the fans are ok, you may have a bad lamp. remove the lamp and check for bulges, black spots, fogging or flaking. also see if there is dust caked on the vent screen on the lamp. if you have any of those, replace the lamp. it is blown.
Feb 09, 2010 | InFocus ScreenPlay 4805 Multimedia...
Replaced a bulb and the red lamp light still comes on and the projector turns off
colorwheel or ballast need replacing. when you turn it on, listen for a high-pitched whir. if you hear it, the ballast is bad. if you don't, replace the colorwheel.
Oct 30, 2009 | Optoma EP716 Multimedia Projector
Infocus 1n32 show the bulb is bad but when replaced the unit still will not light up.
could also be a bad colorwheel or ballast. if you hear a high-pitched whir when you start it up, the colorwheel is working and the problem may be the ballast. in no whir, replace the colorwheel.
Oct 06, 2009 | InFocus Office Equipment & Supplies
I have a projector that is powering up but there is no light coming from the lens. I changed the bulb and still the same thing. When it powers up it sounds almost like a harddrive inside is skipping...
the colorwheel may be bad. if the colorwheel doesn't spin correctly, the lamp won't light. turn it on without the lamp in. look inside the lamp housing and see if the multi-colored glass disk (colorwheel) is spinning. if it isn't, or it's laboring, it needs replacing.
Jul 28, 2009 | InFocus Proxima UltraLight X350 Multimedia...
50 inch samsung model hln5065w
Depending on the version of software in the unit additional service alignments may be required.If the colorwheel was changed and the picture was fine before and now is bad this is the case.Only an authorized Samsung service center will have this information.In the colorwheel box there should have been a little sticker with the new peramaters required to align the new colorwheel to the software version.
Jan 14, 2009 | Samsung HLN5065W 50" Rear Projection...
Dp 1200x
only 3 things cause no light: bad lamp, bad ballast, bad colorwheel, or bad fan. if you feel the fan blowing and the lamp is good, do you hear a high pitched whir? if yes, the colorwheel works and it may be the ballast. if not, or it chirps, it's the colorwheel.
Jun 10, 2008 | ASK Proxima DP1200x Multimedia Projector
RCA HD50LPW42 50" Rear Projection HDTV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
