Question about Creative Labs ZEN V Plus MP3 Player
Help me! hi. i did the reload firmware. and when i turned it off right when i did that, it said firmware problem or something and it keeps going to the recovery mode screen! what do i do to get to my home screen with my musicA! and i need help with the restriction volume does that mean i erased the password for it? do i just type one in random?
    President:
  • 4,402 Answers
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
good luck
please mark the post with a fixya
Posted on Apr 24, 2008
When i turn it on the little android keeps spinning will not go to desktop
Android operating system is corrupt.
Reload the firmware, but you will loose your data.
Pick your correct android tablet. Support Firmware
Feb 19, 2014 | Kocaso Tablets & eReaders
Reloading firmware on creative zen
Do you mean you want to update the firmware? Or your player is frozen?
If frozen, there's a hole in the left side of the device, the restart button is in there, find something thin enough and push it.
To update your firmware, go to www.creative.com and download the latest firmware installer, dock your zen with your PC and run the installer, following it's instructions as you go.
Feb 07, 2010 | Creative Labs Zen V MP3 Player
"Firmware Problem" on screen
Before turning it on, press and hold the play/pause button and turn it on simultaneously. A screen should come up with four options. Go to the one that says reload firmware and select it. Please note that doing this will erase all of the music and other stuff off of your player, so back it up. If after you reload firmware it and it still does not work, you can go here to get a new firmware update from this site which should make your player work: http://support.creative.com/downloads/welcome.aspx?nDriverType=4&bLatest=1
Apr 06, 2009 | Creative Labs Zen Digital Media Player
My sansa e280 mp3 player stopped working i dnt knw y
I'm unable to assume the exact problem with your mp3 player as you've bluntly said that the device is not working. Try the following steps and that should work. If not let me know:
  SOLUTION 1 - Reset the device
Resetting the Sansa View/Fuze
Resetting the e200/c200 series
SOLUTION 2
 - Reload and update to the latest firmware
STEP 1 - Enable MSC or Recovery mode
Enable MSC mode on e200v2 / c200v2 / Fuze
Force Recovery mode on e200v1 / c200v1 / e200R / View
STEP 2 - Update to the latest firmware
You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware
Sansa Fuze firmware update
Sansa View firmware update
Sansa e200 series firmware update
Sansa c200 series firmware update
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 31, 2009 | SanDisk Sansa e260 MP3 Player
I have a RAC 66
Go to the Garmin website and the download tab. it has all the firmware and software to reload,
Hope this helps as you say you have a 510. Don't know what a RAC 66 is?
Nov 30, 2008 | Garmin StreetPilot c510 Deluxe GPS...
My Zen will not keep time.
Have you tried to reload the firmware? You may need to also do a format. Click here to download the firmware.
For more detailed instructions on how to troubleshoot your Zen, click here
Aug 13, 2008 | Creative Labs Zen Digital Media Player
Recovery mode
bad hard drive, Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Apr 15, 2008 | Creative Labs ZEN V Plus MP3 Player
Doesnt start up
Hi. My Inovix mp3/4 player suffered a similar fate when it crashed during a Firmware reload. The player went completely dead and wasn't even recognised by the computer when plugged into the USB port. I basically kept on trying - a couple of times whenever I used the computer - using different ports. 2 days later - 'ding-dong' - Windows XP suddenly recognised something was in the port, and I tentatively attempted a Firmware reload. Success! (Don't ask me to explain it tho'...)
Aug 28, 2007 | Samsung YP-U2X Digital Media Player
Stuck on recovery mode
you probably just to need to re-install/update the firmware. if you turn it on and just after the zen logo the little ahazard sign appears, it says something like "problem with firmware," that's your fix. the same thing happened to me when i followed what it said on the site to troubleshoot the display, but they're all assholes and instead of fixing it, murdered the player. oh, and be prepared to have everything on there erased. yeah, it sucks :-(
Jun 04, 2007 | Creative Labs ZEN Vision:M Digital Media...
Firmware not reloading
Take out the battery, press and hold the ON switch and reinsert the battery. Hold the ON switch until the recovery menu appears shortly after the Creative Logo disappears. Selection option 3, which is to reload the firmware. Keep in mind that doing so will delete everything on the player.
Oct 19, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
37 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
