Question about Honeywell Heating & Cooling
I have a Honeywell Programmable Thermostat T8600 and nothing displays. It was working fine, and the A/C was on on Saturday. I checked the display on Sunday and the thermostat was blank. All other lights are on around it so the circuit braker is fine, and the a/c was working the day before. I have taken the front part off the wall and the wiring looks fine, but I am not an electric expert. I don't know if there is something simple I can try to fix it. Thanks.
Check your transformer for power, should get 24V reading, if transformer is out make sure there are no short otherwise your new one will have the same fate.before checking the transformer however, make sure that your dedicated breaker for the air handler and your switch in the attic is turned on.
Posted on Apr 10, 2010
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Rth111 does not turn on when cold
too cold for batteries or they are low. Litium Ion work well in the cold but check tstat instructions for compatibility.
Jun 12, 2017 | Honeywell Programmable Thermostat Heater
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
120 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
