Question about Dryers
Need to replace on off switch in a kenmore dryer and cannot get the panel cover off
    Scholar:
  • 178 Answers
I need more info on your dryer to be able to assist you. Post a reply to this or ask me with a model number. I'll be glad to help then.
Posted on Apr 16, 2008
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
How do i take off the back panel on my kenmore 90 series gas dryer? There is a separate smaller panel at the top of the machine, dark brown metal that looks to be overlapping the actual panel. Should I...
the smaller panel your talking about covers the back of the controls on the top of the machine , unless your working on one of those switches, there is no need to remove that
Oct 03, 2011 | Kenmore Dryers
I need a wiring diagram for a Kenmore 110.86872100. replacing the thermostat and the heater element, don't want to cross wires. Can you help?
If you remove the cover from the back of the dryer control panel there will probably be a wiring diagram for your dryer folded up and taped to the back. Something to try if you can't find it otherwise.
May 23, 2010 | Kenmore Dryers
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Kenmore 70 series dryer wont start. I was going to replace the start button but cannot figure out how to get it off with out breaking stuff. do i need to pull all the panels off?
There is a switch that sits behind that start button. To get to it, unplug the dryer and pull it away from the wall. There is a metal cover that runs along the upper rear side of the dryer -- remove that and you will see the switch behind that button. You can disconnect the wires going to it (you may want to mark them) and pull the button off of the front of the switch. Then pull that plastic tab up and the switch will pop out if you twist it clockwise.
May 29, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenore Senor Smart 27-inch dryer control panel not working
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 20, 2009 | Kenmore 72062 Gas Dryer
Kenmore dryer start switch needs to be replaced
Depending on age of unit.. there are 2 screws on each side of the console (older unit) on newer unit you have 2 white plastic covers.. pop those out and unscrew the 2 screws and lift up the console.. you have to get to the starter switch from the back of console.. good luck..
Jan 21, 2009 | Kenmore 63942 Dryer
My 1999 Kenmore dryer won't start
This is a start switch that would require opening the panel on the front to get to the switch behind the start button. But, i'm not sure this is the problem. If it still doesn't work after replacing the start switch then check the door switch.
This switch is located on the inside front at the door. Jump the two wires together going to this switch, put it back together, close the door, hit the start button. If it starts then it won't stop if you open the door but, you have found the problem.
Dec 19, 2008 | Kenmore 63942 Dryer
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove lint filter
  • remove 2 screws in lint filter holder
  • with putty knife or other blunt blade
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Richard Roth
Richard Roth
