Question about Dryers
Dryer will not start when door is shut and button is pushed. I have checked the plug into wall. The model is PYE/G2300,3300 and it is about four years old. I need advise on who to call for repairs.
    Genius:
  • 1,073 Answers
Contact whirlpool at 800-874-4698 to see who is the nearest servicer
Posted on Apr 15, 2008
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
My dryer was workin yesterday i stopped to get a shirt out an shut the door then pushed start but nothin happened
Try unplugging it and plugging it back in then starting it like a new load. My grandkids have opened the door while ours is running and that seems to help.
Feb 13, 2011 | Kenmore Dryers
I have a gas dryer that the igniter plug glows, but does not light the gas. One time when I had the front panel off the gas ignited and the dryer heated, but only burned for a minute then shut off. Now I...
with front off it will short cycle. If ignitor glows and then goes out without lighting, you have bad burner coils. The 2 black round things on burner assembly. Unplug unit then unplug coils and remove bracket with 2 screws. install coils and test.
Aug 27, 2010 | Dryers
Gas dryer does not start when ignition button is pushed.
a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Dec 22, 2009 | Frigidaire FGQ332ES Gas Dryer
My Maytag Atlantis dryer won't start. I checked
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 15, 2009 | Dryers
Maytag Performa Electric Dryer will not turn on
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Jun 07, 2009 | Maytag Dryers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
No response when start button is pushed
check you door switch make sure it there and not broke off,,,onthejob
Dec 23, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
