Question about Tomtom XL 330 Car GPS Receiver
Tom tom is on all ik get is a flashing x on it
  • 515 Answers
Go to:
http://www.tomtom.com/support/index.php?Language=4&query=red+cross&FID=6363
Follow instructions...
(Please remember to rate...)
Posted on Apr 16, 2008
Factory reset gps
UNFREEZE Tom tom sat nav USING WINDOWS OR MAC PC
This will unfreeze your tom tom after exhausting every avenue this works!
You will need Internet access.
Ensure you have the correct tom tom desktop softwear installed on your computer for your tom tom device.
If not then download from tomtom
Removed sim card from tom tom located under sticker lower end of tom tom.
Carried out on a windows laptop with windows 7
(Note this should also work on mac although I did not get to try it and it is stated you will need rosetta on intel macs)
Ensure you download the flash tool for tomtom (clear_flash.dmg) for your operating system windows or for the mac VERY IMPORTANT YOU HAVE THE TOOL DOWNLOADED FIRST.
1.For windows: www.tomtom.com/updates/clear_flash/clear_flash.exe
connect tom tom to computer
find the tom tom on your computer and select all the files
you can firstly copy these to another location or separate drive before deleting all files.
Now delete ALL the tom tom files
Format your tom tom to FAT32 if using windows (im not sure of the mac settings yet)
Keep your tom tom connected to your computer
Run the flash tool and Flash the tom tom memory with the tool.
Restart your tom tom
It will update (but this time it should work!)
Select done after update
Tomtom reboots (restarts)
It may ask you to install a new update but there may not be any update to install just
Select yes to update.
Eject tom tom from your pc by selectinglower right corner symbol.
Now unplug device if ejected correctly
Congratulations your device should now work again.
Note I did not replace my sim card as it is not required to work the gps.
Hope this helped someone.
My device does not keep its settings What should do
Aug 14, 2014 | Tomtom TOM TOM ONE WE V3 GPS Receiver
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
Ik heb een samsung gt b3210 ik krijg mijn gsm niet open het valt telkens uit als ik het aanzet vraagt soms pin code achteraf valt het terug uit wat kan het probleem zijn met laden heb ik geen problemen...
Dat had ik ook maar anders.. weet niet of het helpt maar zit er een geheugen kaart in .. bij mij zat er wel eens in,, die was blijkbaar stuk , en me mobiel begon te koken en laade niet meer, ik heb geheugen kaart er uit gehaalt en nou doet ie het weer:D maar ik denk niet dat het helpt
Mar 07, 2011 | Samsung Cell Phones
Wanneer ik de mobigo aansluit op de computer lijkt alles goed tegaan. ik drukte op setup en het verbaasde me dat hij gaf. Vtech not device. please connect your vtech device to the computer, turn the device...
Ik heb hetzelfde probleem en ik vermoed nu dat het komt omdat je nog niet via de nederlandse site kan installeren??
iets anders kan ik niet meer verzinnen, aangezien er bij de instructies duidelijk staat vtechnl.com
ik heb nu geprobeerd via US en UK maar dus dezelfde melding
Er staat op de vtechnl website dat het halverwege 2011 te downloaden is.
hopelijk is dat het, en kunnen we het dus halverwege 2011 wel geinstalleerd krijgen.
mocht je een andere oplossing vinden hoor ik het graag
Mar 06, 2011 | Vtech Mobigo Learning System
Canon PIXMA MP610. Error 5200. Appears immediately after power on. Green light flashing alternating with yellow light flashing. Do I need to buy a new printer?
als ik mag vragen hoe ik het probleem kan oplossen er blijft een groen en geel lamp kniperen en ik kan de printer helemaal niet gebruiken hulp graag
Feb 10, 2011 | Canon PIXMA MP130 All-In-One InkJet...
QUEStion About Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV>>>>
5 flashes is IK or current to cathode. check the IC's on the crt boards, check the focus block, check the vertcal deflection IC since the IK pulses come from the verticl cicuit.
Mar 16, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Tomtom XL 330 Car GPS Receiver Logo
44 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
